Why can't I configure BFD for static routes on IAD2431 on ios 15.1(2)T when Feature Nav says its in there
Alfred Johnson
I am trying to configure BFD for static routing on a 2431 running IOS 15.1(2)T to detect and route around simple multihoming faults.  According to Cisco Feature Navigator, BFD for static routes is supported on c2430-ik9o3s-mz.151-2.T.bin.  But when I follow the config guide steps to configure it, IOS does not recognize the commands, such as:
ERC3-IAD2431-3(config)#int fa0/0
ERC3-IAD2431-3(config-if)#bfd ?
% Unrecognized command
and:
ERC3-IAD2431-3(config)#ip route static bfd fa0/0 172.19.113.241
% BFD is not supported on FastEthernet0/0
Am I missing some prerequisite, or restriction?
Vignesh Rajendran Praveen
Kindly provide the outputs of show version and show interface.
Thanks & Regards,
Vignesh R P
Vignesh,
As requested:
ERC3-IAD2431-3#show version
Cisco IOS Software, 2400 Software (C2430-IK9O3S-M), Version 15.1(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 19-Jul-10 16:23 by prod_rel_team
ROM: System Bootstrap, Version 12.3(7r)T2, RELEASE SOFTWARE (fc1)
ERC3-IAD2431-3 uptime is 1 week, 20 hours, 31 minutes
System returned to ROM by reload at 15:45:52 EDT Mon Oct 27 2014
System restarted at 15:47:56 EDT Mon Oct 27 2014
System image file is "flash:c2430-ik9o3s-mz.151-2.T.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco IAD2431 (R527x) processor (revision 4.1) with 250880K/11264K bytes of memory.
Processor board ID FHK1444F1GM
R527x CPU at 225MHz, Implementation 40, Rev 3.1
2 FastEthernet interfaces
48 Serial interfaces
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
63K bytes of non-volatile configuration memory.
System fpga version is 250027
System readonly fpga version is 250027
Option for system fpga is 'system'.
126976K bytes of ATA System CompactFlash (Read/Write)
ERC3-IAD2431-3#show int fa0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 5475.d026.3019 (bia 5475.d026.3019)
  Description: Uplink to TWC/Avaya VoIP Network
  Internet address is 24.30.210.144/27
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 3 packets/sec
  5 minute output rate 1000 bits/sec, 2 packets/sec
     40541 packets input, 6155984 bytes
     Received 20517 broadcasts (0 IP multicasts)
     0 watchdog
     149623 packets output, 22178324 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     17 unknown protocol drops
     0 lost carrier, 0 no carrier
ERC3-IAD2431-3#show int fa0/1
FastEthernet0/1 is up, line protocol is up
  Hardware is Gt96k FE, address is 5475.d026.301a (bia 5475.d026.301a)
  Internet address is 172.19.113.242/29
  Last input 00:00:44, output 00:00:05, output hang never
     14829 packets input, 3324508 bytes
     Received 7916 broadcasts (0 IP multicasts)
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     78596 packets output, 7819210 bytes, 0 underruns
     0 output errors, 0 collisions, 13 interface resets
     0 unknown protocol drops
ERC3-IAD2431-3#
Alfy
