Bookmark
Subscribe
486
ASR 1002X loop reboot
CWMBRASIL
I can't give the command to enter rommon, I'm connected via console, any solution?
Initializing Hardware ...
System integrity status: 00000610
System Bootstrap, Version 16.7(1r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: Watchdog/ICH
SPI Flash 4KB Descriptor Area Checksum = 0x6f5a0db2
ASR1002-X platform with 16777216 Kbytes of main memory
File size is 0x2b4fa621
Located asr1001x-universalk9.17.06.03a.SPA.bin
Image size 726640161 inode num 33, bks cnt 177403 blk size 8*512
Boot image size = 726640161 (0x2b4fa621) bytes
ROM:RSA Self Test Passed
ROM:Sha512 Self Test Passed
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
calculated 29412044:0096f764:7152460f:c879e2a9:15ff163c
expected 29412044:0096f764:7152460f:c879e2a9:15ff163c
Validating main package signatures
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
* load-cpld.service - CPLD Kernel Driver
Loaded: loaded (/usr/lib/systemd/system/load-cpld.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2024-08-17 14:55:34 Universal; 55ms ago
Process: 113 ExecStart=/cpld_util.sh (code=exited, status=1/FAILURE)
Main PID: 113 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
>>> Rebooting
@CWMBRASIL
 It should be
Control + Break
or
Control + Pause
shambhu.kumar
If you are using putty, click on top left and special then break. Please restart your  router and click break tab.
It will comes rommon 1 > prompt , then
rommon 1 > dir bootflash:
boot with existing file using
rommon 2 > boot bootflash:file -name
