Why did the Summary Null Route disappear from the ABR's Routing Table
jwangCisco
Hi Experts,
Just testing out the simple theory...
I could not figure out why a route was missing from the ABR's routing table :
Could anybody please shed light for me:
I understood the theory that said : [ when you place the
Area Range
command on the ABR, then a Summary route to null0 was supposed to be installed into this ABR’s routing table ].
It did not happen on my ABR router.
I had labbed it up using Packet Tracer , with the following configurations, and a Summary Null route is currently missing from Router B’s table :
Please see my simple topology diagram :
Router B is the NSSA ABR , and is connecting to two areas : the backbone internal Router A, as well as connecting to Area 1 NSSA Router C (NSSA ASBR) .
**** Below is the configuration for NSSA ABR (Router B)
hostname Router
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
 ip address 10.1.2.2 255.255.255.0
interface FastEthernet0/1
 ip address 1.1.1.1 255.255.255.0
router ospf 24
 log-adjacency-changes
 area 0 range 10.0.0.0 255.0.0.0
 area 1 nssa
 network 10.0.0.0 0.255.255.255 area 0
 network 1.0.0.0 0.255.255.255 area 1
ip classless
ip flow-export version 9
no cdp run
end
**** Below is the configuration for the Backbone internal Router A:
hostname Router
no ip cef
no ipv6 cef
 ip address 10.1.1.1 255.255.255.0
 ip address 10.1.2.1 255.255.255.0
router ospf 24
ip classless
end
**** Below is the configuration for NSSA ASBR (Router C
hostname Router
no ip cef
no ipv6 cef
 ip address 1.1.1.2 255.255.255.0
 ip address 172.16.1.1 255.255.255.0
router ospf 24
 area 1 nssa
 redistribute rip subnets
router rip
 redistribute ospf 24
 network 172.16.0.0
ip classless
end
**** Below is the configuration for the RIP Router
hostname Router
no ip cef
no ipv6 cef
 ip address 172.16.1.2 255.255.255.0
 ip address 172.16.2.1 255.255.255.0
router rip
 network 172.16.0.0
ip classless
end
**** Here is the output “show ip route” for Router ***********
Gateway of last resort is not set
     172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C       172.16.1.0/24 is directly connected, FastEthernet0/0
L       172.16.1.2/32 is directly connected, FastEthernet0/0
***** Here is the output “show ip route” for Router C: ***********
    1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       1.1.1.0/24 is directly connected, FastEthernet0/0
L       1.1.1.2/32 is directly connected, FastEthernet0/0
O IA 10.0.0.0/8 [110/2] via 1.1.1.1, 02:13:08, FastEthernet0/0
C       172.16.1.0/24 is directly connected, FastEthernet0/1
L       172.16.1.1/32 is directly connected, FastEthernet0/1
****** Here is the output “show ip route” for Router B: ***********
C       1.1.1.0/24 is directly connected, FastEthernet0/1
L       1.1.1.1/32 is directly connected, FastEthernet0/1
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.1.2.0/24 is directly connected, FastEthernet0/0
L       10.1.2.2/32 is directly connected, FastEthernet0/0
     172.16.0.0/24 is subnetted, 1 subnets
O N2    172.16.1.0/24 [110/20] via 1.1.1.2, 01:56:15, FastEthernet0/1
**** Here is the output “show ip route” for Router A: ***********
     1.0.0.0/24 is subnetted, 1 subnets
O IA    1.1.1.0/24 [110/2] via 10.1.2.2, 02:11:36, FastEthernet0/1
C       10.1.2.0/24 is directly connected, FastEthernet0/1
L       10.1.2.1/32 is directly connected, FastEthernet0/1
O E2    172.16.1.0/24 [110/20] via 10.1.2.2, 02:11:36, FastEthernet0/1
Much Appreciated for your good trouble shooting knowledge
According to your output it should work. To test it I also labbed up your example (minus extra configs and RIP router since it was irrelevant). I was able to produce a summary route of Null0. It may be just a buggy Packet tracer. Try configuring from scratch again (just the OSPF routers) or maybe do a reload.
Another indicator you at least know summarization is working by the output of RouterC. It would see both 10.1.0.0 networks from Router A. The fact it sees only one as a /8 means your summary is getting downstream.
Hope that helps
-David
17 Replies 17
I might be wrong, but I seem to recall that you cannot use the
area range
command in area 0. Try area 1 for that range, the null route will show up....
Thank you George.
In the past, I had read it somewhere, published by Cisco, that it was acceptable practice to summarise routes from the backbone direction, into other non-backbone areas.  If I should come across it again, you bet, I am going to copy and paste that valuable document here. ( My memory might be wrong though, so please feel free to point me to the relevant Cisco article).....thanking you for your awesome speedy ray of light
I think I get issue here
in router B and all router the wildcard is config wrong
 ip address 10.1.2.2 255.255.255.0<-mask
router ospf 24
 area 1 nssa
 network 10.0.0.0 0.255.255.255 area 0<<--here wildcard must us not mask so it must be 0.0.0.255, this i think make area range not work.
I like your thinking MHM, so I had labbed it up, but the Summary Null route was still missing in action from the ABR's table... thank you with gratitude
sorry I don't have PKT in my Mac,
I TEST it in GNS3 even wrong wildcard the summary appear.
so as @David Ruess test it is bug.
Odd. I just recreated the topology, and now it works as predicted:
RouterB
router ospf 1
router-id 1.1.1.1
network 1.1.1.1 0.0.0.0 area 1
RouterB#sh ip route
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
10.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
O 10.0.0.0/8 is a summary, 00:00:58, Null0
C 10.1.2.0/30 is directly connected, GigabitEthernet0/0
L 10.1.2.1/32 is directly connected, GigabitEthernet0/0
Great. I was just about to upload my files as well. At least I got some practice configuring OSPF summary
I was able to re-create it in packet tracer and GNS3. I'm sure you're good but if you still want the files let me know.
I will say in packet tracer it was a bit buggy. I had to reload the routers and wait another minute or 2 before it showed the summary route which I thought was weird. And another minute before it showed up on the router C downstream.
-David
same as Me, still this issue from my side need more deep study wildcard and area range and NSSA and area 0.
later if I get any update I will share it here.
Hope that helps
-David
@David Ruess Do you care posting your configs ? For some weird reason, in GNS3, I could not get a null route for area 0, as soon as I changed it to any other area, the null route appeared right away...
yes please also @Georg Pauwen can you share your config
When I get home this afternoon I will.
Hello
Your topology doesn’t support the configuration you have posted in relation to the addressing, Also given that the rip process looks like it has auto summarization enabled and is running ver 1 which is classful so doesn’t understand cidr’d address space, plus I would suggest to append
rip metric
to the ospf redistributed routes.
Another possibility is that PT doesn’t by default have discard route enabled, which on proper software the discard (internal/external) is enabled.
Try the following:
rtrb
router ospf 1
discard-route internal
rtrc
router rip
version 2
no auto-summary
redistribute ospf x metric 5
rtrd
router rip
version 2
no auto-summary
Kind Regards
Paul
Thank you Paul , you had good suggestions there as well, but I personally prefer to let simple theory work on its own , without extra bells and whistles , if my network must get too complicated, just to make a simple theory work, then something in my own network design need to improve ..... I need to strive to make Cisco router my soul mate... Thank you so much for lending a hand
