why do some routers have int VLAN 1 configured by default?
ccnaluna93
I thought that VLAN interfaces were only used by switches, but I have seen this ina router:
Router>show ip int br
GigabitEthernet0/0/0 unassigned YES unset administratively down down
GigabitEthernet0/0/1 unassigned YES unset administratively down down
GigabitEthernet0/0/2 unassigned YES unset administratively down down
Vlan1 unassigned YES unset administratively down down
balaji.bandi
Cisco routers can have built-in or optional, add-on switch modules. The interfaces for this module are switch interfaces, not router interfaces. You need to create VLAN interfaces to link the layer-2 switch to the layer-3 router.
BB
8 Replies 8
balaji.bandi
BB
Thanks for your reply. At work I have a Cisco 4331 which has a SM-X-ES3-24-P sw module, it works as another device, but when I checked the
sh ip int br
command I don't see any created vlan interface, the only virtual LAN purpose interface used is a BDI50, it's a bit strange because I've seen other routers like this that have vlan interfaces
yes that is cisco default vlan part of IOS code, but there is no use until you have switch module in it.
BB
Ok I got it, so if we don't have any switch module in use, then that vlan interface is useless, right?
yes you got it right !
BB
This is an interesting aspect to think about. I believe that for most of the traditional IOS routers (such as the 4300 series) I have never seen them by default have an interface vlan 1, with switch module or without switch module. I am thinking about some other router models (perhaps the 800 series, or the Small Business series) and believe that I have seen the default vlan 1 interface on them. Perhaps the original poster can post the show version of the router from which he got the output in the original post so that we can understand what model of router this was?
Perhaps the bottom line here is that while we tend to think of Cisco as a single entity that there are multiple product lines (some appealing to different markets, and different levels of sophistication) and different implementations of their OS, and that we do not always see the same behavior when we look across these product lines or OS variants.
Rick
Sure, I've seen this in a Cisco4331, here we have an active switch module but interface vlan is not being used...
01>sh ver
Cisco IOS XE Software, Version 16.06.08
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 23-Apr-20 19:06 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
01 uptime is 3 weeks, 6 days, 2 hours, 41 minutes
Uptime for this control processor is 3 weeks, 6 days, 2 hours, 43 minutes
System returned to ROM by PowerOn
System restarted at 19:38:10 GMT Tue Dec 22 2020
System image file is "bootflash:isr4300-universalk9.16.06.08.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 FoundationSuiteK9 Permanent FoundationSuiteK9
securityk9
appxk9
AdvUCSuiteK9 AdvUCSuiteK9 Permanent AdvUCSuiteK9
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None appxk9
uck9 None None uck9
securityk9 None None securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 3843991K/6147K bytes of memory.
Processor board ID FLM235012D
5 Virtual Ethernet interfaces
3 Gigabit Ethernet interfaces
2 Serial interfaces
4 Voice FXS interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6598655K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
01>Show cdp nei det
Device ID: sm1
Entry address(es):
IP address: 11.x.x.x
Platform: cisco SM-X-ES3-24-P, Capabilities: Router Switch IGMP
Interface: Ethernet-Internal1/0/0, Port ID (outgoing port): GigabitEthernet0/26
Holdtime : 167 sec
Version :
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 15.2(4)E7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
01>Show ip int brief
GigabitEthernet0/0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/2 unassigned YES NVRAM administratively down down
Serial0/1/0 201.x.x.x YES NVRAM up up
Serial0/1/1 unassigned YES NVRAM administratively down down
Service-Engine0/2/0 unassigned YES unset up up
Service-Engine0/4/0 unassigned YES unset up up
Ethernet-Internal1/0/0 unassigned YES unset up up
Ethernet-Internal1/0/1 unassigned YES unset up up
GigabitEthernet0 unassigned YES NVRAM administratively down down
Loopback0 11.x.x.x YES NVRAM up up
Vlan50 11.x.x.x YES manual up up
Vlan100 11.x.x.x YES NVRAM up up
Vlan500 11.x.x.x YES NVRAM up up
Vlan900 11.x.x.x YES NVRAM up up
Now I have another question, why do we use segment 11.x.x.x for all LAN segments, we should use private segments, shouldn't we? haha it is kind of weird
Thank you for the output. And +5 for showing me an aspect of IOS XE that I had not noticed before. Looks like it is the case that when you have a switch module that it does generate the vlan 1 default interface.
Rick
