why do you need VRFs for VXLAN
carl_townshend
Hi Guys
I recently built a layer 2 vxlan in my test environment between 2 routers, the same vlan was presented at each end and it works fine.
I have default anycast gateway on each end to allow them to route out of this vlan.
Can someone tell me why we need layer 3 vni's and vrf's?
Could I just not replicate the same for each vlan that I have done already, would this not allow them to route out of the vlan like a normal SVI would do inter vlan routing?
cheers
It not mandatory.
MHM
Hi, so why do they recommend this so called transit vrf? What if I don’t have it?
so if I don’t have this it would just route using the normal vlan gateway ?
Transit VRF? Can you more elaborate?
Now for vxlan there is underlying which is global
And overlying which is ONE vrf for one vlan svi for route type 5 or multi vlan in same vrf.
Engineer recommend using one vrf for each vlan to separate the L3/L2 of traffic between different VLAN.
MHM
