Why EIGRP is not redistributed into BGP within VRF
frank
Why my EIGRP routes are not redistributed in BGP within the VRF?
The EIGRP routes (172.16.1.0/24 and 172.16.2.0/24) are in the table as following:
r6#sh ip route vrf CRG001
Routing Table: CRG001
172.16.0.0/24 is subnetted, 2 subnets
D 172.16.1.0 [90/409600] via 10.116.20.3, 18:30:04, Ethernet1/0
D 172.16.2.0 [90/409600] via 10.116.20.3, 18:30:01, Ethernet1/0
10.0.0.0/24 is subnetted, 5 subnets
B 10.116.30.0 [20/0] via 10.116.21.2 (CRG005), 1d01h
B 10.116.31.0 [20/0] via 10.116.21.2 (CRG005), 1d01h
C 10.116.20.0 is directly connected, Ethernet1/0
B 10.116.10.0 [20/0] via 10.116.20.2, 18:41:29
B 10.116.11.0 [20/0] via 10.116.20.2, 18:41:29
r6#
But are not in the BGP table:
r6#sh ip bgp vpnv4 vrf CRG001
BGP table version is 9076, local router ID is 172.16.56.6
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 2:1 (default for vrf CRG001)
*> 10.116.10.0/24 10.116.20.2 0 0 65208 10 i
*> 10.116.11.0/24 10.116.20.2 0 0 65208 10 i
*> 10.116.30.0/24 10.116.21.2 0 0 64600 i
*> 10.116.31.0/24 10.116.21.2 0 0 64600 i
r6#
Here is my config:
router eigrp 113
no auto-summary
address-family ipv4 vrf CRG001
network 10.116.20.0 0.0.0.255
no auto-summary
autonomous-system 1
exit-address-family
router bgp 65231
no synchronization
bgp log-neighbor-changes
timers bgp 3 9
no auto-summary
redistribute eigrp 1
neighbor 10.116.20.2 remote-as 65208
neighbor 10.116.20.2 activate
neighbor 10.116.20.2 next-hop-self
no auto-summary
no synchronization
network 10.116.20.0 mask 255.255.255.0
exit-address-family
mheusing
That is an interesting question, because the config excerpt you give looks correct. In addition 10.116.20/24 is also missing in the VRF BGP table.
Did you try to remove and readd the redistribution statement?
Could you provide the VRF and interface configs as well?
Regards, Martin
Hi Martin,
The reason for 10.116.20.0/24 is not in BGP table was because I have import route-map to block that.
Here is my config for VRF and interfaces:
ip cef
ip vrf CRG001
rd 2:1
import map CRG001_import
route-target export 2:1
route-target import 2:1
route-target import 2:5
interface Ethernet1/0
ip vrf forwarding CRG001
ip address 10.116.20.1 255.255.255.0
ip as-path access-list 1 permit ^64600$
route-map CRG001_import permit 10
match as-path 1
router eigrp 113
no auto-summary
no auto-summary
autonomous-system 1
exit-address-family
router bgp 65231
no synchronization
timers bgp 3 9
no auto-summary
no auto-summary
no synchronization
exit-address-family
Martin,
Looks like I found my own problem, the import route-map also need to include ^$ and it is OK now...
ip as-path access-list 1 permit ^$
r6#sh ip bgp vpn vrf CRG001
BGP table version is 9649, local router ID is 172.16.56.6
*> 10.116.20.0/24 0.0.0.0 0 32768 i
*> 10.116.21.0/24 0.0.0.0 0 32768 i
*> 172.16.1.0/24 10.116.20.3 409600 32768 ?
*> 172.16.2.0/24 10.116.20.3 409600 32768 ?
r6#
