2600 routable ip address basics
ryan_perc_admin
Hello all,
Bare with me as I'm new to the CIcso configurations.
I am working on bringing up a 2600 series router to be used as the gateway to our ISP.
I have the Serial interface configured so that it will communicate with the provided default route and now I would like to configure servers on the LAN side with routable ip addresses, so I'm looking for someone to look over my config and give me some incite before I put the router into production.
Here is the information from the ISP (ips changed)
Local WAN IP Address: 200.200.50.118 255.255.255.252
Remote IP Address: 200.200.50.117 255.255.255.252
Ethernet IP Address: 201.200.150.165 255.255.255.224
Primary Domain Name Server: 200.200.40.10
Secondary Domain Name Server: 202.200.51.16
Here is the config thus far.
version 12.2
service password-encryption
hostname cicrtr
logging queue-limit 100
enable secret 5 $1$blah$blah%blaV2rUJaL2.
enable password 7 00110011110011001
ip subnet-zero
ip name-server 200.200.40.10
ip name-server 202.200.51.16
ip audit notify log
ip audit po max-events 100
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address 201.200.150.165 255.255.255.224
duplex auto
interface Serial0/0
ip address 200.200.50.118 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
no fair-queue
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
interface FastEthernet0/1
ip address 10.0.0.20 255.255.255.0
duplex auto
speed auto
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 205.214.50.217
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
exec-timeout 15 0
line aux 0
line vty 0 4
exec-timeout 30 0
login
I want to run 201.200.150.170 as the firewall / routable interface from to internal LAN to the router via a Linux box.
Is there anything specific that I missing?
8 Replies 8
Edison Ortiz
The config looks fine, just connect the 201.200.150.170 device directly to the router's Fa0/0 interface.
They should be able to ping each other.
The default gateway on the 201.200.150.170 should be 201.200.150.165
I'll put it into production and see how it goes.
Ryan
One more thing I noticed, you have a default route to a non-directly connected interface.
Your next hop IP for the default route should be 200.200.50.117
bvsnarayana03
Level 5
Level 5
What is this IP address 205.214.50.217??
it doesnt seem to be a connected device. you may want to replace this with 200.200.50.117 which is the coonected interface of ISP router.
it is a typo... I noticed after I posted.
The acutal router is teh following (i don't know if I can change my origianl post)
ip route 0.0.0.0 0.0.0.0 200.200.50.117
The acutal route is the following (i don't know if I can change my origianl post)
Ryan
There are some aspects of what you have set up that are not clear to me. You have a /30 public address on the serial interface which suggests that the path from your network to the ISP is through the router serial interface. If that is the case I am not clear how the firewall will function if it is connected on the Fa0/0 interface. The subnet on that interface is a /27. Are there other devices connected on that interface and in that subnet?
In my experience most people with a router connected to an ISP want to do some amount of filtering at the interface that faces the ISP (at a minimum filter out spoofed addresses, private addresses, etc) but I do not see any access lists on the router at all.
I am also puzzled about the devices in the subnet of FA0/1. The subnet there is in private address space so would I be correct in assuming that your user devices are in that subnet? If so what will direct their traffic to the Internet through the firewall? And if traffic from network 10 is going to the Internet there needs to be address translation. Where will the address translation take place?
Can you clarify some of these things?
Rick
Rick
