Why set origin attribute in bgp only take effect after reset bgp session?
ilovebgp4
hi!Dear all
It is said that "clear ip bgp neighbour-address soft out" will make routing policy take effect WITHOUT reset the bgp session;but when I do a lab to set the origin attribute in bgp route this command doesn't works.I must use "clear ip bgp neighbour-address" to reset bgp session to make it works.Is it?And are there other attritbutes in bgp be modified will take effect only after the bgp session reset?
below is my configration:
router bgp 100
no synchronization
bgp log-neighbor-changes
aggregate-address 192.168.192.0 255.255.248.0 attribute-map setorigin suppress-map filter
redistribute eigrp 100
neighbor 192.168.1.253 remote-as 200
neighbor 192.168.1.253 send-community
neighbor 192.168.1.253 route-map COMMUNITY out
no auto-summary
access-list 101 permit ip host 192.168.192.0 host 255.255.248.0
route-map setorigin permit 10
match ip address 101
set origin incomplete
In this lab I must reset the bgp session between this router and it's peer to let the route-map "setorigin" take effect.
Thanks a lot for your help!
2 Accepted Solutions
Harold Ritter
The "clear ip bgp soft out" will usually do the trick for policies that are applie outbound on the neighbor. In your case the route-map is configured on the attribute-map on the aggregate statement. Try adding the "set origin incomplete" to the existing outbound route-map COMMUNITY. The "clear ip bgp soft out" should then work.
Hope this helps,
BTW: if you want the new policy to take effect in your current configuration without resetting the session, you could just remove and re-apply the aggregate statement. This will do the job too.
Hope this helps
5 Replies 5
Harold Ritter
Hope this helps,
Hope this helps
hi!hritter
Thanks for your help!
bhedlund
Level 4
Level 4
I could be wrong but something doesn't look right with access-list 101 as it is shown in the configuration...
Please rate all helpful posts.
Brad
Hi Brad,
When using an extended access-list with BGP, the 'source' portion of it matches the 'prefix' of the route and the 'destination' portion of it matches the mask of the prefix....
So in this case, ACL 101 matches 192.168.192.0/255.255.248.0 only..
Paresh
