Cisco 7304 and OSPF
mpalis
Hello all
We have a few Cisco7304 we are having problems with unstable ospf. We are having two of them in a an enviroment where we have several C7401 , C7609 and C7513. The ospf of 7340 whith the other routers is very untable while the OPSF between all the other router in the network is OK. All routers are in the same area. C7304 have two Interfaces,one GE and one FE. Problem is on the GE side. GE has about 45Megs of traffic. IOS that we are currently running is :c7300-js-mz.122-20.S8.bin. We did try several IOS for the C7304 but all are having their unique problems.
From debuging it seems that the C7304 is not processing the OSPF hellos it receives from the neighbor. The remote neighbor stays in the INIT state. The strange thing is that it does not loose all its neighbors at the same time.. It may loose some of them and after a while some other at random...
byousaf
Try moving the link from the existing GE to another GE on a diffrent linecard?
bhedlund
Level 4
Level 4
My initial hunch here is that the 7304 is not establishing a clean, error free, link to the network.
Did you check for input errors on each side of the GE link?
Please rate all helpful posts.
Brad
