Why subinterface for Circuit?
ohforce55
Why does some ISPs provide subinterface to their customer for circuit?
And what's the case when they just provide with a physical interface?
Which ISPs usually do provide subinterface?
Thank you in advance!
Philip D'Ath
Using sub-interfaces allows you to sell different seperate services to a client (such as VoIP and data).
The question about which ISPs do this will depend on what country you are talking about.
Philip,
Thanks for your reply!
ISPs in the US, which ISPs usually provide subinterface?
And what's the case they just give physical interface to client?
All of them in some form at some point in their ISP network will be using subs depending on what service technology is in place
A direct p2p link that has no tagging on it would not require sub interface , straight BGP link into the MPLS also should not require sub your side anyway but there side may differ as it could be point to multipoint there end
Julio E. Moisa
It could be because they are using Virtual Circuits like used for L2 VPN ATOM, EoMPLS, L2TPv3, VPLS, etc. So you can assign one VLAN per client.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
