Why the BGP next-hop is inaccessible?
iceking2nd
There are some configuration of my Cisco 6506-E, the IOS version is (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF17b
C6506E#show run | b r b
router bgp 64517
template peer-policy Route-Opt
route-map Route-Opt in
route-map BROADCAST_LOCAL out
exit-peer-policy
bgp router-id 124.202.129.196
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 124.202.11.21 remote-as 17964
neighbor 124.202.11.25 remote-as 17964
neighbor 172.18.0.13 remote-as 64513
neighbor 172.18.0.17 remote-as 64513
maximum-paths 4
address-family ipv4
redistribute static
neighbor 124.202.11.21 activate
neighbor 124.202.11.21 inherit peer-policy Route-Opt
neighbor 124.202.11.25 activate
neighbor 124.202.11.25 inherit peer-policy Route-Opt
neighbor 172.18.0.13 activate
neighbor 172.18.0.13 route-map BROADCAST_LOCAL out
neighbor 172.18.0.17 activate
neighbor 172.18.0.17 route-map BROADCAST_LOCAL out
maximum-paths 4
no auto-summary
no synchronization
network 118.145.16.0 mask 255.255.254.0
network 124.202.128.56 mask 255.255.255.252
network 124.202.129.196 mask 255.255.255.255
exit-address-family
C6506E#show route-map Route-Opt
route-map Route-Opt, permit, sequence 10
Match clauses:
as-path (as-path filter): 101
Set clauses:
ip next-hop 202.99.1.30
Policy routing matches: 0 packets, 0 bytes
route-map Route-Opt, permit, sequence 65535
Match clauses:
Set clauses:
local-preference 200
C6506E#show ip route 202.99.1.30
Routing entry for 202.99.1.30/32
Known via "static", distance 1, metric 0
Redistributing via bgp 64517
Advertised by bgp 64517
Routing Descriptor Blocks:
* 172.18.0.13
Route metric is 0, traffic share count is 1
172.18.0.17
C6506E#ping 202.99.1.30
Sending 5, 100-byte ICMP Echos to 202.99.1.30, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
C6506E#show ip bgp regexp _4808$
BGP table version is 14031, local router ID is 124.202.129.196
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network          Next Hop            Metric LocPrf Weight Path
*  27.131.220.0/22  202.99.1.30                            0 17964 65008 17816 4837 4808 i
BJ-CY-JXQ-C-M35.1-SC-C6506E#show ip bgp 27.131.220.0
BGP routing table entry for 27.131.220.0/22, version 0
Paths: (2 available, no best path)
Multipath: eBGP
Not advertised to any peer
202.99.1.30 (inaccessible) from 124.202.11.21 (202.99.1.27)
Origin IGP, localpref 100, valid, external
Why the next-hop 202.99.1.30 is inaccessible?
Edison Ortiz
BGP checks the interface the next-hop was learned from. If 202.99.1.30 was learned via a different interface than the one use to peer with 124.202.11.21, then the route will be marked as inaccessible.
Edison Ortiz
How can I fix it?
Take a host route from 172.18.0.13 in BGP?
Or disable any feature in BGP?
Establish BGP Peer with Loopbak interface,and set the ebgp-multihop.
Thanks.
Using the loopback for BGP peering was a very sound approach.
By using the loopback, you need to advertise it via an IGP and the routers peering with BGP will learn the loopback subnet via the same interface the next-hop was learned from.
Thanks for the rating and welcome to the forums!
