Why the difference in cables - WIC-1T vs. WIC-2T?
pipemajor
I have a home CCNA lab w/2501(3) routers and just acquired a 2620XM router that has 2x WIC-T1DSU cards. I'd like to get a serial card or two to connect to my 2501 routers but the 2501 serial ports and WIC-1T ports use the DB-60 connector while the WIC-2T uses something entirely different.
I have 2 emply slots on my 2620XM, should I just go for a pair of WIC-1T cards?
hpoel
There simply isn't enough space on the front of a WIC for 2 DB-60 connectors, so Cisco came up with the 'SS' (small scale?) connector.
Other than that, you could use either WIC-1T or WIC-2T. Make sure you get the right pair of cables one MT and one FC to connect the routers together (or make your own back-to-back cable).
hpoel
