WIC-1DSU-T1-V2 on 1841 Cisco Router configuration
johnnyfranks
I am having a issue with a WIC-1DSU-T1-V2 on 1841 Cisco Router. I am following guide lines on-line per a WIC-1DSU-T1 (without V2) which is according to cisci.com pdf/page is to be configured with service-module commands rather than controllers but I can't bring the status of the Serial 0/0/0 to come up. I am trying to bridge a point-to-point to the same type of interface and 1841 router on the other end. Can someone explain to me what I am missing please. I've tried the following:
Interface serial 0/0/0
service-module t1 clock source line
service-module t1 timeslots 1-24 speed 64
service-module t1 framing esf
service-module t1 linecode b8zs
ip address 192.168.1.1 255.255.255.248
encapsulation ppp
fair-que
no shutdown
but only the following saves or shows up after a "show run":
"interface Serial0/1/0
encapsulation ppp
fair-queue
service-module t1 timeslots 1-24"
and here is the full "show int"
#show int ser 0/1/0put errors, 0
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Closed, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:17:25
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 36 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
Thank you.
johnnyfranks
PS never mind the 0/1/0 and 0/0/0 mix up in the above txt. This is because like I mentioned I am trying to bridge a point to point between two actually three routers...the third will support the incoming NIU. Thanks for your help/advise!
