Cisco 1811 router
mon_samonte
1. Does cisco 1811 router supports WAN Failover?
2. How will I configure it & also the config of load balancing?
spremkumar
Level 9
Level 9
Cisco 1811 comes with 2 FE WAN Interfaces and a 8 port Switch.
do revert back where you have your wan links connected and how do u want to achieve load balancing ?
regds
Hi mate,
Thanks for the reply.
I will be using 2 dsl line & the client wants to enable WAN Failover & load balancing. I knew with this configuration. I can't find any supporting documents or sample config on cisco site. Do you have sample config so that I will have an idea on how to configure it?
Thanks again.
You can enable load balancing using static routes by pointing to the gateway with same metrics.Also CEF can be enabled.
Pls visit the following link.
http://www.cisco.com/warp/public/105/46.html
JD
