How to Start implementation of Routing Protocol
imranraheel
I have to implement a routing protocol in my network environment how to start as i have 3 routers 20 servers 2 pix and few other routers which are connected to me.Now when ever a clients connects to my network i have to define a route which is the best possible way to implemt a routing solution
spremkumar
Level 9
Level 9
Hi Imran
You need to throw more lite on what you are exactly doing by defining a route.
You need to post out the topology in which the routers/servers/pix firewalls are connected and when/where you are adding route..
regds
jackyoung
Level 6
Level 6
Please provide the network diagram w/ all router, switch, server, firewall connection.
If only a few routers and assume no VLAN, static route may be enough that require a better IP address scheme that easily to use summarize route to simplify the routing table.
Or use dynamic routing protocol for easier deployment if there are more segments. EIGRP may be good enough for simple routing design.
More info. is required for more suggestion. Check Cisco web for the samples.
Hope this helps.
