WIC 4ESW and routing
resoh
Hi All,
I have a 1721 router with a WIC 4ESW 4 port switch card and an integrated T1 controller.
I have a T1 to the core of my network going into this Cisco 1721 router. I need have all the devices plugged into the 4 port switch on one network and the T1 controller on another network. These two networks converge at the 1721 router. When I plug the router in eigrp advertises the route of the serial interface that is directly connected. The problem that I am looking to solve is how can I get the network that I am using for the 4 port switch to advertise?
below is my config.
version 12.4
service password-encryption
hostname
boot-start-marker
boot system flash c1700-ipbasek9-mz.124-25a.bin
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login telnet local
aaa session-id common
clock timezone est -5
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.143.0.0 10.143.2.0
ip dhcp excluded-address 10.143.2.4 10.143.255.255
ip dhcp pool 143
network 10.143.0.0 255.255.0.0
default-router 10.143.1.254
lease 0 8
no ip bootp server
no ip domain lookup
interface FastEthernet0
no ip address
speed auto
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Serial0
ip address 192.168.143.2 255.255.255.0
interface Vlan1
ip address 10.143.1.1 255.255.0.0
router eigrp 1
network 10.0.0.0
network 192.168.143.0
no auto-summary
no eigrp log-neighbor-changes
ip default-gateway 10.143.1.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.143.1
no ip http server
no ip http secure-server
control-plane
line con 0
login authentication telnet
line aux 0
line vty 0 4
ntp server 10.220.42.200 prefer
end
8 Replies 8
Edison Ortiz
The 4 ports belong to Vlan 1 and you have an IP address under Vlan 1.
This address is already under the EIGRP process.
Are you saying the remote EIGRP neighbors aren' receiving this route?
Can you post the show ip route from this router and remote neighbors?
___
Edison.
Roy
Edison is correct that your EIGRP should advertise the network of the VLAN. One thing that is necessary for that to happen is for the VLAN to be in an up/up state. Can you post the output of show ip interface brief to verify whether the VLAN is up?
Rick
Rick
Looks like vlan 1 is up/down
#sh ip int bri
FastEthernet0 unassigned YES NVRAM up down
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
FastEthernet4 unassigned YES unset up down
Serial0 192.168.143.2 YES NVRAM up up
Vlan1 10.143.1.1 YES NVRAM up down
One of those ports (F0 - F4) needs to be up/up for Vlan 1 to be up/up.
Once Vlan 1 is up/up, it will be advertised into EIGRP.
HTH,
__
Edison.
The vlan 1 interface comes up when I plug in a device, and the route to the 10.143.0.0 network shows up. I can now ping from the remote 10.143.0.0 network to the core but I can not ping from the core to the remote network 10.143.0.0 network. I can ping the router serial interface 192.168.143.2 from the core, but I can't ping a device on the 10.143.0.0 network. I am able to ping interface vlan 1 ip address 10.143.1.254
BTW i changed the interface vlan 1 ip address to 10.143.1.254 (it was 10.143.1.1)
If you can ping from a client in the 10.143.0.0/16 subnet to the core but you are unable to ping from the core back to the client, I suggest to make sure the client does not have any FW enabled.
__
Edison.
FW not enable still same issue.
You could have overlapping subnets somewhere in your routing table.
Check the routing table from the Core and make sure it goes to the respective spoke.
__
Edison.
