WIC Card showing as embedded-service-engine
mannatech
All,
  I am having trouble with a WIC card that was recently installed. It is for an MPLS circuit. When it was added to the router, it came up showing as an embedded-service-engine.  It isn't even close to something like that. Is there a way I can make the router see it as a serial interface which is what this is?  I did manage to get the card to show up/down.  But in order for everything to work, I need it to be a serial int.  I have provided some output that may help.
Scott
UARouter#sh diag
Slot 0:
        C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 4 ports
        Port adapter is analyzed
        Port adapter insertion time 00:35:49 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC17037LN8
        Hardware Revision        : 1.0
        Part Number              : 73-11835-11
        Top Assy. Part Number    : 800-30794-07
        Board Revision           : A0
        Deviation Number         : 130603
        Fab Version              : 03
        Product (FRU) Number     : CISCO2921/K9
        Version Identifier       : V08
        CLEI Code                : CMMHS10ARB
        Processor type           : C2
        Chassis Serial Number    : FCZ1712610S
        Chassis MAC Address      : b0fa.ebd2.68b0
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 37 30 33 37 4C 4E 38 40
          0x10: 06 16 41 01 00 82 49 2E 3B 0B C0 46 03 20 00 78
          0x20: 4A 07 42 41 30 88 00 01 FE 2B 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 32 31 2F 4B 39 89 56 30 38 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 53 31 30 41 52
          0x50: 42 09 C2 C2 8B 46 43 5A 31 37 31 32 36 31 30 53
          0x60: C3 06 B0 FA EB D2 68 B0 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0226-03
        Deviation Number         : 0
        PCB Serial Number        : DCA1702K2HP
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V03
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 03 88 00 00 00
          0x10: 00 C1 8B 44 43 41 31 37 30 32 4B 32 48 50 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F3 18 3B 02 F0 19 D9 03 E8 1B 76
          0x60: 04 E2 1C 49 05 D9 1D 1B 06 D8 1D ED 07 CF 1E BF
          0x70: 08 CE 1F 40 09 C2 1F B8 0A B8 20 34 0B B7 20 B0
          0x80: 0D AF 21 0C 0F 9F 21 67 11 91 21 94 13 87 21 C0
          0x90: 17 6E 21 DB 1B 57 21 EA 1F 3F 21 E2 23 28 21 D4
          0xA0: 27 0A 21 CD 42 41 30 FF FF FF FF FF FF FF FF FF
UARouter#SH INT
Embedded-Service-Engine0/0 is up, line protocol is down
  Hardware is Embedded Service Engine, address is 0000.0000.0000 (bia 0000.0000.0000)
  Description: Sprint
  Internet address is 172.20.12.2/30
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Input queue: 0/64/0/0 (size/max/drops/flushes); Total output drops: 1
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     1 packets output, 375 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Embedded Service Engine 0/0 :
   Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
UARouter#sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 172.20.12.2     YES NVRAM  up                    down
paolo bevilacqua
WIC card does not show up at all as. All ISR G2 routers have the embedded service engine interface, that you can ignore.
Paolo,
  Could you be a little more specific?  I am just trying to get the WIC card recognized as a WIC card. Hod do I ignore the service engine?  Once it is ignored, how can I use my WIC card?
Which card is that exactly ?
Ignoring means is not related to the problem, and do not have to do anything about.
Perhaps the output of show inventory from the router might shed some light on this?
Rick
Rick
