Wildcard masks question
milkdroogy
if i have this wildcard mask:
0.0.0.15
does it mean that the "do-care" bits are the last 15 bits? so in binary its:
10000000.00000000?
and how i interpret this wildcard mask:
0.0.15.255
7 Replies 7
GillieLucent
0.0.0.15 doesn't mean last 15 bits, here 15 means decimal value 15 for last octet.
for 0.0.15.255, binary is below :
00000000.00000000.00001111.11111111
if you want to know how 00001111 becomes 15, here comes
0 x 128
0 x 64
0 x 32
0 x 16
1 x 8
1 x 4
1 x 2
1 x 1
15
Only in subnet mask you can represent in bits as like below :
130.100.200.10/24 and
130.100.200.10 255.255.255.0 are same.
If you are not clear feel free to ask more.
Vijaybabu
well ok so 15 means decimal value - but what does it represent? what does this 15 mean?
As said in the revious post 15 is the decimal value of the octet
for eg. 0.0.0.15
This means the last octet is having a decimal value of 15 i.e 00001111 or (0F in hex). When using wildcard masks the 1's bit are dont care bits.
hence 172.16.100.0 0.0.0.15 would match all address between 172.16.100.1 - 14
Similary 0.0.15.255 would mean the last 12 bits are dont care bit.
10.10.0.0 0.0.15.255 would match all addresses from 10.10.0.1 - 10.10.15.254
HTH, rate if it does
Narayan
IP address is 4 octets.In every octet there are 8 bits, when converting an octet into decimal value, each bit is associated some value as below :
1st bit ( from left) - 128
2nd -64
3rd -32
4th -16
5th -8
6th -4
7th -2
8th -1
so for 00001111
0 x 128
0 x 64
0 x 32
0 x 16
1 x 8
1 x 4
1 x 2
1 x 1
15
Hope this helps.
Pls rate the posts.
Vijaybabu
if you got into binary then i have a question:
i know that
10000
01111
but how do i do that on paper?
i mean -
1-1 = 0
0-0 = 0
1-0 = 0
0-1 = 1(?)
how do i do that?
Well it goes something like this
since you cannot subtract 1 from 0 you borrow the digits ..something similar what you do with decimals
say for eg you need to subtract 28 from 52
i.e 52-28 (here you borrow one from 5 which makes it 4 and the carried digit with 2 becomes 12 and so 12-8=4 & 4-2=2 i.e 52-28=24
Similarly to do subtraction in binary 10000-01111 you will borrow the digit
1 - borrowed over & hence becomes 0
0 - becomes 10(i.e 2) again 1 gets borrowed over leaving 10-1 = 1 (ie 2-1=1)
this continues till you reach the last digit
where you have 10-1=1 and rests cancel out.
There is another method where you use the 2's component to achieve the same
10000 - 01111
complement 01111 -- becomes 10000 (just
reverse the digits)
add one to get the 2's complement
10000+1=10001
Add this to 10000 i.e 10000+10001=100001
Remove the higher order digit to get 00001
You got me back to engg days :-)
Easy method now would be to use calculator
Narayan
Thanks man!
its just that I'm studying now for my CCNA-ICND exam, that's why i have all this silly questions
