Wireless part of the network cannot receive packets
ciguzis
you need to make the changes marked in bold to your router. Attached the revised fiile.
Router#wr
Building configuration...
[OK]
Router#sh run
Current configuration : 987 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
interface FastEthernet0/0
--> ip address 10.0.0.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 20.0.0.2 255.0.0.0
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
interface FastEthernet6/0
ip address 30.0.0.2 255.0.0.0
duplex auto
speed auto
interface FastEthernet7/0
ip address 70.0.0.2 255.0.0.0
duplex auto
speed auto
router rip
ip classless
--> ip route 192.168.0.0 255.255.255.0 FastEthernet0/0
ip flow-export version 9
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
Hello
1 -Give your servers the correct default gateway of the router-PT interfaces
2- wifi router requires its isp link to be statically onfigured with a 10.0.0.254 255.0.0.0 address with a default-gateway of router PT -  10.0.0.1
3- router -PT require a static route towards the wifi router  192.168.0.0 255.255.255.0 10.0.0.254 (specifying ip next-hop  to negate arp)
This should allow the wifi laptop users to reach the servers and pcs however the server and pvcs cannot reach the laptops, I would assume this is because of the wifi rtr is only allowing established traffic to enter ( basic firewall function)
Kind Regards
Paul
