wireless vlans/ssids
gregthornton1
I'm trying to setup a 1131 AP with three different ssids corresponding to three separate vlans.  I feel I'm close to completing this but I can't seem to get all three online at the same time.  ssid MickeyMouse seems to always be active and functioning properly.  But when I issue the command mbssid guest-mode, that ssid becomes active and the 3rd doesn't show up.  I would like to have MickeyMouse and MinnieMouse active for internal use, and Visitor to be for guests/vendors, thus only able to get out to the internet.  How can I get all three ssids operational?  Then I'll just need to add them to broadcast out on the other radio also.  Here is my current (edited) config.  Thanks for any assistance
version 12.4
no service pad
service password-encryption
hostname HOME-AP-01
enable secret 5 $1$C3Dr$CG4zHGcd/67zBATjOPygh0
no aaa new-model
dot11 ssid MickeyMouse
   vlan 200
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 0805434008150133070807
dot11 ssid MinnieMouse
   vlan 220
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 15360A05172F32003D303E
dot11 ssid Visitor
   vlan 222
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 063C06316F410D1C544343595B
power inline negotiation prestandard source
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 encryption vlan 200 mode ciphers aes-ccm
 encryption vlan 220 mode ciphers aes-ccm
 encryption vlan 222 mode ciphers aes-ccm
 ssid MickeyMouse
 ssid MinnieMouse
 ssid Visitor
 station-role root
interface Dot11Radio0.200
 encapsulation dot1Q 200 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.220
 encapsulation dot1Q 220
 no ip route-cache
interface Dot11Radio0.222
 encapsulation dot1Q 222
 no ip route-cache
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
interface FastEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet0.200
 no ip route-cache
 bridge-group 1
interface FastEthernet0.220
 no ip route-cache
interface FastEthernet0.222
 no ip route-cache
interface BVI1
 description LAN interface
 ip address 192.168.200.12 255.255.255.0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
Saurav Lodh
Level 7
Level 7
  • Enable the broadcast service set identifier (SSID) on the WLAN—With the broadcast SSID enabled, the WLAN/SSID information is sent in the beacons. This also help the clients that perform passive scans (those that do not transmit probe request), as well as clients configured without an SSID to associate with the WLC through this WLAN.
  • Also check the Signal strength
kaaftab
Level 4
Level 4
check the step by step guide for configuring multiple SSID in autonomous AP
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-3_7_JA/configuration/guide/i1237sc/s37ssid.html
Thanks for the replies.  All my work has been through the cli, but I went into the gui to confirm things like in your link, and when I go under Security->SSID Manager, there are no SSIDs listed.  Not even the < NEW > is listed.
