Cannot ping different subnet
parisvcisco
Until now we haven't had much config on our switches so everything is running on vlan1. I've been setting up a new vlan but wanted to give the switch an ip address on vlan1 for now so I did:
interface Vlan1
 ip address 192.168.120.240 255.255.192.0
ip default-gateway 192.168.120.248
Once I did this our monitoring server which is on a different site - ip 10.1.1.20 cannot see/ping the switch anymore.
It's a Cisco 2960 layer 2 switch.
What do I need to do in order for this switch to be able to see the 10.1.1.0/24 subnet?
I'm a bit of a beginner so excuse me if I have explained it in the most technical way!
Just change your IP route to:
ip route 0.0.0.0 0.0.0.0 192.168.120.248
22 Replies 22
mmoulson1
Level 4
Level 4
When you say "Once I did this our monitoring server which is on a different site - ip 10.1.1.20 cannot see/ping the switch anymore."
How was is setup previously when it worked?
If your switch has an IP of 192.168.120.240 255.255.192.0, it will need to go to it's default gateway to talk to 10.1.1.0/24.
What devices sit between the subnets? If it is another site do you have a VPN or some kind of WAN?
I think a diagram would be helpful!
our default gateway is 192.168.120.248 which is the inside interface of our cisco pix 515e firewall. (We don't use a router)
it's configured to use a site to site vpn with an asa5520 which has clients on the 10.1.1.0/24 subnet
OK so is it just the switch that can't talk over the VPN?
Can you PING from a host on the 192.168.120.X network to 10.1.1.20?
yes.
I also have a layer 3 switch which had the same issue so I did:
ip route 10.1.1.22 255.255.255.0 192.168.120.248
But I guess this is a quick fix for that switch rather than a solution!
Does your 2960 not support the 'ip route' command?
no, as I understand it this only works on layer switches.
there isn't an ip route command.
I wonder why it could ping 10.1.1.22 before I did:
interface Vlan1
Hello
"I wonder why it could ping 10.1.1.22 before I did:"
That's what we are trying to establish for you,
Can you post the run ning config of this access switch and the core highlighting the physical interfaces they are connected with.
res
Paul
Kind Regards
Paul
I think it depends on the IOS version running on your 2960:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swipstatrout.html
Like Paul said if you can post your running config?
Also I have noticed on various different ports spanning tree is set to either point to point or rapid pvst. Not sure if this is correct?
At the moment this network is one big single point of failure something I would like to sort out!
I'm no STP expert but globally you have:
nmysw03
spanning-tree mode rapid-pvst
nmySW04
spanning-tree mode pvst
nmysw05
"spanning-tree link-type point-to-point Recommended for rapid-PVST+ mode only"
"The rapid PVST+ is available only if you have the EI installed on your switch."
Have a look at:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2950/software/release/12-1_14_ea1/configuration/guide/2950scg/swstp.html
Firewall - nmypix01:
Cisco PIX Security Appliance Software Version 8.0(4)
Hardware:   PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
interface Ethernet1
 description Internal Network (192.168.113.0/18)
 speed 100
 duplex full
 nameif inside
 security-level 90
 ip address 192.168.120.248 255.255.192.0 standby 192.168.120.249
interface Ethernet1.1
 vlan 20
 nameif guest
 security-level 80
 ip address 192.168.1.248 255.255.255.0 standby 192.168.1.249
access-list inside-vpn extended permit ip 192.168.113.0 255.255.192.0 10.1.1.0 255.255.255.0
access-list site-to-site extended permit ip 192.168.113.0 255.255.192.0 10.1.1.0 255.255.255.0
access-list split-tunnel standard permit 10.1.1.0 255.255.255.0
ethernet1 connects to nmysw03 fa0/15
WS-C2950T-24
Version 12.1(22)EA6
nmysw03#sh run
Building configuration...
Current configuration : 4379 bytes
! Last configuration change at 16:42:09 GMT Thu May 29 2014
! NVRAM config last updated at 15:20:07 GMT Thu May 29 2014
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname nmysw03
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
errdisable recovery cause bpduguard
errdisable recovery cause link-flap
errdisable recovery interval 400
mls qos map cos-dscp 0 8 16 26 32 46 46 56
ip subnet-zero
udld aggressive
no spanning-tree optimize bpdu transmission
macro global description cisco-global
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/15
 description nmypix01 - eth1
 switchport trunk allowed vlan 1-4,20
 switchport mode trunk
 switchport nonegotiate
 speed 100
 duplex full
interface FastEthernet0/16
 description nmypix02 - eth1
 speed 100
 duplex full
interface GigabitEthernet0/2
 description Netgear GS748T
 switchport trunk allowed vlan 1,20
 speed 1000
 duplex full
 flowcontrol receive desired
interface Vlan1
 ip address 192.168.120.245 255.255.192.0
 no ip route-cache
interface Vlan20
 no ip address
 no ip route-cache
line con 0
 exec-timeout 0 0
line vty 0 4
 exec-timeout 30 0
 password 7
 login
line vty 5 15
 password 7
 login
end
Gi0/2 connects to a netgear switch nmysw02 port 1 - Maybe this is where the problem lies!
It has 802.1Q enabled Vlan1 untagged and default vlan 1 on all ports then vlan20 tagged on the trunks
ip settings:
DHCP Disabled
IP address 192.168.120.241
Subnet mask 255.255.192.0
Default gateway 192.168.120.248
port 48 connects to the switch in question nmysw04 Gi0/2
WS-C2960-24PC-L
12.2(50)SE4
C2960-LANBASEK9-M
nmySW04#sh run
Current configuration : 1790 bytes
version 12.2
no service pad
hostname nmySW04
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
vlan internal allocation policy ascending
 description trunk to nmysw02
interface Vlan1
 ip address 192.168.120.244 255.255.192.0
 no ip route-cache
interface Vlan20
 no ip address
 no ip route-cache
ip http server
ip http secure-server
control-plane
line con 0
 password 7
 login
line vty 0 4
 exec-timeout 30 0
 password 7
 login
line vty 5 15
 login
end
I've just spotted on nmysw04 it didn't have a default gateway set!
It can ping the 10.1.1.xxx subnet now!
The layer 3 switch nmysw05 did have this set however but wouldn't ping until I did the ip route command. I'll pasted config in a sec.
nmysw05#sh run
Current configuration : 5952 bytes
! Last configuration change at 13:34:29 UTC Mon Jun 2 2014
version 15.0
hostname nmysw05
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
switch 1 provision ws-c3650-24ps
ip routing
ip device tracking
ip dhcp pool guest_wifi
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.248
 dns-server 8.8.8.8 8.8.4.4
no errdisable detect cause gbic-invalid
diagnostic bootup level minimal
redundancy
 mode sso
class-map match-any non-client-nrt-class
  match non-client-nrt
policy-map port_child_policy
 class non-client-nrt-class
    bandwidth remaining ratio 10
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/24
interface Vlan1
 ip address 192.168.120.237 255.255.192.0
 no ip route-cache cef
interface Vlan20
 ip address 192.168.0.1 255.255.255.0
ip http server
ip http authentication local
ip route 10.1.1.0 255.255.255.0 192.168.120.248
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
!UKTD-SW-ITS-02#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
UKTD-SW-ITS-02(config)#no ip route 10.1.1.0 255.255.255.0 192.168.120.248
UKTD-SW-ITS-02(config)#end
UKTD-SW-ITS-02#ping 10.1.1.22
Sending 5, 100-byte ICMP Echos to 10.1.1.22, timeout is 2 seconds:
Success rate is 0 percent (0/5)
UKTD-SW-ITS-02(config)#ip route 10.1.1.0 255.255.255.0 192.168.120.248
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/6/10 ms
So our layer 3 switch can only ping 10.1.1.xxx once the ip route has been set even though default gateway has been configured.
