Wlan solution
aga_huseynov
Hi everyone and I wish every one Happy new year
So I have got one problem about Wlan
so I configured wlan with 801.x security how ever it doesn;t work normally in roam enviroment is there any solution for this I mean is the cisco has the solution about this feature I don;t want use wep or wpsk I want use certificate with 801x so authenmtication via radius to Active directory so plzzz let me know if there any solution abt this one thanks
Istvan_Rabai
Level 7
Level 7
Hi Agha,
Yes, definitely there is a solution.
Look at this page:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml
Cheers:
Istvan
thanks for u quick response but if I have no cisco AP so can I use it with other Ap for example 3com and linksys will it work
Hi Agha,
I don't have experience with these compatibility issues.
You probably should look for the answer on forums specific to these vendors.
Cheers:
Istvan
