Would like to use VoIP from HQ to Branches?
rechard_hk
Dear All,
I would like to ask all of you some question that i would like to use voip from HQ to my branch.
The connection from HQ to branch i used VPN site to site and the connection is working but i don't know
which equipment  that i can use Voip from HQ to branch?
Note: at HQ site i used Router 2811 and Branch site i used Router 1841.
Best Regards,
Rechard
conmurph
Hi Rechard,
You can find a few sample configurations as well as the best practices in the SRND and also have a look at the CME configuration guides for more information.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/cmesrnd.html
As mentioned above, if you are the end user it is strongly advised to speak with a Cisco partner who can assist you with the design and implementation.You can use the Partner Locator tool to find a partner in your area.
http://tools.cisco.com/WWChannels/LOCATR/openBasicSearch.do
Cheers,
Conor
conmurph
Hi Rechard,
How many phones do you need to support? If you have a small setup, the 2811 supports up to 35 phones using Communications Manager Express. You'll need purchase the CME software, CME license, DSP's, IP phones and phone licenses. Have a look at the SRND below for the best practices and deployment scenarios.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/data_sheet_c78-520029.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/models.html
Also, if you have access to partner central you can have a look through the CME ordering guide to find out what you need.
http://www.cisco.com/web/partners/sell/technology/ipc/integrated-solutions/ip_telephony.html#~3
Cheers,
Conor
Dear Conor,
Thank you for your link!!!
At my HQ around 100 user , and branch around 5-10 user.
I would like to ask you again some question on my system.
Currently my system using Panassonic (PABX) how can migrate (how to connect it)?i mean how my user when the want to call to outside (CO line)?
if i purchase CME (HQ), Should i purchase at branch site or not?
do i need to buy module card for vocie or not?
Do you have simple configuration on Voip from HQ to branch site by VPN connection?
Best Regards,
rechard
Are you the end user ? I recommend you engage a certified cisco partner, or reputable professional, otherwise it will take a lot of time and potential frustration for you to reach o prefessional result.
conmurph
Hi Rechard,
Cheers,
Conor
