WPA2 on ISR Routers (871W or 1811W)
clausonna
Level 3
Level 3
It seems that WPA2 is not supported on ISR routers, only true Access Points:
http://www.ciscotaccc.com/wireless/showcase?case=K68400254
Anyone know if/when WPA2 will be supported? Is this just an IOS software issue, or will it require a hardware upgrade?
Thanks.
- Neil
amit-singh
Level 8
Level 8
Hi Amit,
Thanks for the research! However when I go onto the router (871W 12.4.9T1 AdvIPServices) and try to set the encryption mode, I don't see AES as an option:
871W-router(config)#int dot11radio0
871W-router(config-if)#encryption mode ciphers ?
tkip WPA Temporal Key encryption
wep128 128 bit key
wep40 40 bit key
But if I go onto an 1130AP, for example:
1130AP(config-if)#encryption mode ciphers ?
aes-ccm WPA AES CCMP
ckip Cisco Per packet key hashing
ckip-cmic Cisco Per packet key hashing and MIC (MMH)
cmic Cisco MIC (MMH)
wep128 128 bit key
wep40 40 bit key
Maybe I'm missing something here, but it seems that if I can't set the encryption to AES then I'm not really doing WPA2.
I'll keep researching as well and post anything that I find.
Turns out WPA2 on ISR's is going to be supported in the next release of IOS, due out by the end of 2006.
