different output show
AmandMimoza
Hi ,
I have two different output commands for the same interface atm5/1/0 ?
Every body know why ?
Router #sh int atm5/1/0
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 149357
Output queue :0/140 (size/max)
Router#sh controllers vip 5 tec-support
ATM1/0 is up, line protocol is up
Hardware is ENHANCED ATM PA
MTU 4470 bytes, sub MTU 0, BW 34013 Kbit, DLY 200 usec,
reliability 0/255, txload 1/255, rxload 1/255
Encapsulation ATM, loopback not set
Last input never, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 37
Queueing strategy: fifo
Output queue :0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1406 input errors, 1406 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
router#sh ver
IOS (tm) RSP Software (RSP-PV-M), Version 12.2(7c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 11-May-02 14:26 by pwade
Image text-base: 0x600109C8, data-base: 0x611C6000
ROM: System Bootstrap, Version 11.1(8)CA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: RSP Software (RSP-BOOT-M), Version 12.0(17a), RELEASE SOFTWARE (fc1)
wve-tzw-01-abr uptime is 33 weeks, 1 day, 2 hours, 3 minutes
System returned to ROM by reload
System restarted at 11:30:37 MET Tue Mar 7 2006
System image file is "slot0:rsp-pv-mz.122-7c.bin"
cisco RSP4 (R5000) processor with 131072K/2072K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
Chassis Interface.
4 VIP2 R5K controllers (6 FastEthernet)(2 ATM).
6 FastEthernet/IEEE 802.3 interface(s)
2 ATM network interface(s)
123K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
Slave in slot 7 is running Cisco Internetwork Operating System Software
IOS (tm) RSP Software (RSP-DW-M), Version 12.2(7c), RELEASE SOFTWARE (fc1)
Compiled Sat 11-May-02 06:01 by pwade
Slave: Loaded from system
Slave: cisco RSP4 (R5000) processor with 131072K bytes of memory.
Configuration register is 0x102
I attached also router?s show version .
Best regards
wochanda
Level 4
Level 4
The VIP uploads the interface counters to the RSP every 10 seconds or so, after which it clears its own. The best place to look at interface counters on a 7500 is on the RSP itself.
OK,
But my problems is related to the modify parameters output queue, before it was 40 packets max queue, I put it to 140 packets, we can view this at output show interface atm5/1/0.
But when I looking for output queue parameters in the output commands: show controllers vip 5 tec-supports, I find the older parameters ( 40 packets ).
I try to down load the vip code ( reseat the slot 5 ) but nothings change.
Thank You
Best regards
