WS-C3750X-24T-S Switch can not see contents of flash or copy ios image
hi.
i copied a wrong IOS image to WS-C3750X-24T-S switch so the switch does not boot.i booted from recovery mode.but when i want to copy a file using xmodem , or when i want to see contents of flash it gives me the following errors:(the pictures are attached)
unable to stat flash
or other errors.
i haven't been able to see the contents of the flash nor copy the previous ios image.
i have attached the picture of the messages.
what can i do?
and another picture:
bamitowpritow
can you try dir flash without the ":"
it does not work.it says no such device.
have you tried to initialize the flash prior by using flash_init
the following document may help you a lot
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
i have already read the article.but when i use the  flash_init  command it's unable to load the iso flash.
i don't know why.i think it can not find flash.
what should i do?
