WS-C6506-E with DCEF2T %IPv4 CEF not running
CiscoadminKZ
Hi guys.
I've just installed card C6800-32P10G in my 6506 with 2T supervisor:
But I noticed, that only L2 traffic could be operated via this card and any L3 traffic couldn't.
I made a lab enviroment:
I connected a PC(10.52.201.201/24) directly to this card, and configured access-port and svi(10.52.201.253/24) in the same vlan. And I can't ping the PC with source of the SVI. But I can do transit ping to this PC via this card from another switch.
I connected to this module and checked cef and cef related tables. And all these tables are empty:
hostname-dfc3#show platform hardware cef
 --- Hardware Entry(ies) from Earl 1(Default Earl) ---
Codes: decap - Decapsulation, + - Push Label
Index  Prefix                Adjacency
-EMPTY-
hostname-dfc3#show platform hardware cef vpn 0 lookup 10.52.201.201
-EMPTY-
hostname-dfc3#show ip cef
But I have the same switch with the simmilar card and all these tables are full of entries.
And I got that ip cef is automatically turned on in this module and I don't need to configure it.
Could you help to figure out what's happening with this card?
Thanks in advance.
andrewswanson
Level 7
Level 7
What is the output of "show cef state" on the switch - excerpt from my 6807 (with VS-SUP2T-10G and C6800-16P10G with DCEF2T) shows:
IPv4 CEF Status:
CEF enabled/running
dCEF enabled/running
CEF switching enabled/running
Does your similar switch that is working ok have "ip cef distributed" command?
hth
Andy
Hi! Thanks for your reply.
The problem was fixed by full switch rebooting
