WS-X6582-2PA question
paul amaral
Level 4
Level 4
1st i would apriciate any thoughts on this.
We have a couple of 2 port adapter Enhanced FlexWANs (WS-X6582-2PA) and i have a few questions on these.
1) Does anyone know if you can assign more I/O memory on each flexwan PA, i looked for a command, while attached to the PA slot and couldn’t find it. Out of 256 Megs of ram it assigns about 68 megs to I/O and on a few PA we only have 30+ megs free not sure if this will become a concern.
FlexWAN-ENH-13/0#sh mem free
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   41291EC0   181854528   113225864    68628664    66629472    55454808
      I/O    C000000    67108352    64034248     3074104     3058576     3066008
2) Does fabric syncing only happen on slot 0 of the flexwan? on slot 1 i never see this on the logs.
SLOT 5/0: 00:00:19: %SSA-5-FABRICSYNC_DONE: Fabric sync on Primary channel done.
SLOT 5/0: 00:00:19: %SCP-5-ENABLE: Module enabled
SLOT 5/0: 00:00:25: %SCP-5-ONLINE: Module online
3) On one of the flexwan when i reboot it i see the follow warning message about upgrading soon, but i have no idea what this means, any insight on this would be great. I'm also seeing ECC errors, does this mean the ram is going bad? i recently had all T1s on this card go down at the same time and the only thing that brought them up was a reboot of the flexwan.
FlexWAN-ENH-13/0#sh log
00:00:07:  Initializing rate limit function ===!!!
SLOT 13/0: 00:00:09: %CWSLC-6-PA_DET: port adapter detected
SLOT 13/0: 00:00:10: %CWSLC-6-PA_SIGVALID: port adapter signal is valid
SLOT 13/0: 00:00:12: %CWSLC-6-PA_SIGVALID: port adapter signal is valid
00:00:17: PM PLD     rev 0x00000071 (valid 0x00000078-00000078) Downrev!
00:00:17: ***************************************************
00:00:17: !!! WARNING: Hardware components are down level !!!
00:00:17: !!! Upgrade soon                                !!!
00:00:17: !!! I mean it!                                  !!!
00:00:17: Currently running ROMMON from ROM F2
SLOT 13/0: 00:00:17: %SYS-5-RESTART: System restarted --
IOS (tm) cwlc Software (cwpa2-DW-M), Version 12.2(18)SXF14, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Thu 08-May-08 00:57 by kellythw
SLOT 13/0: 00:00:17: %HYPERION-5-BUS_MODE_CHANGE: The System Switching Bus Mode chang
ed to Compact mode
00:00:17:
00:00:18: Fabric Information
00:00:18: ==================
00:00:18:  Speed        = 8G
00:00:18:  Channel mode = Mode2-SSA/SSO
00:00:18:  Channel      = Primary
00:00:18:  Serial Primary Channel SYNC SUCCESS!
SLOT 13/0: 00:00:18: %SSA-5-FABRICSYNC_DONE: Fabric sync on Primary channel done.
SLOT 13/0: 00:00:18: %SCP-5-ENABLE: Module enabled
SLOT 13/0: 00:00:20: %SCP-5-ONLINE: Module online
SLOT 13/0: Feb  3 17:28:26: %SYS-5-CONFIG_I: Configured from console by console
Feb  7 09:18:27: Single bit ECC error (0)
Data 0-8 : 0x207B 0x0000 0xFF00 0xFFFF 0xFFFF 0xFFFF 0xFFFF 0xFFFF 0x0280
Data 9-17: 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000
Address  : 0x3CCC 0x0001
Feb  9 17:46:02: Single bit ECC error (0)
Data 0-8 : 0xBFF4 0xFFEF 0xFFFF 0xFFFF 0x3DFF 0x8C08 0xB3B3 0xD799 0x7480
Data 9-17: 0xBF49 0x00F0 0x0000 0x0000 0xB900 0x00C0 0x0000 0x0000 0xA700
Address  : 0x25E1 0x0001
thanks for you time, Paul
2 Accepted Solutions
rsimoni
Hi Paul,
1) no you cannot
2) It is normal. Altough the flexwan2 has 2 Port Adapters it has just one connection to the fabric (at 8Gbps only by the way), so only one synch is technically possible. Developers decided to go for x/0 notation where the 0 does not represent the PA but the module itself.
3) I see the message popping up 2 times (at least). It does not seem good as this indicates a parity error. If you see it often we might consider it a Hard parity error indicating memory problem.  So yes there is a memory or memory controller issue.
Riccardo
This warning message does not mean anything. It does not indicate any error condition and can be safely ignored.
It is a debug message that was not meant to show, but somehow does.
Internal bug "CSCec67502 - CWPA2: Remove debug msgs during bootup" documents that (but you cannot see that).
No actual upgrade is required.
5 Replies 5
rsimoni
Hi Paul,
1) no you cannot
Riccardo
Ricardo, thanks very much for your reply.
Do you or anyone else reading this know what the warning message is all about?
00:00:17: !!! I mean it!                                  !!!"
I have several enhanced flexwans and only see this on one.
Also does the 30 meg free for I/O memory seem low for a PA that has all 28 channels in use? If this was too low and causing issue would I be able to see it on the flexwan logs?
Paul
Could be a "send" message by someone warning everyone to get off.
Thank you Riccardo for letting me know.
paul
