Will BFD (Bidirectional Forwarding Detection) cause extra CPU load?
3alee
Hello all
Could anyone advise if enabling BFD (Bidirectional Forwarding Detection) for BGP on a Cisco 7609 Router causes extra loading on the CPU or impact on Router performance?
Thanks.
Edison Ortiz
Versions prior to 15.1(2)S run BFD in software so depending on the number of BFD sessions, it will affect the CPU hence impacting the router performance.
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html#wp1720514
Edison
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
I've used BFD on 6500, and confirming Edison's reference, have seen CPU impacted, extent of impact also has much to do with BFD frequency.
