Wy use vti for VPN rather than crypto map on physical interface
carl_townshend
Hi all
I see all VPN now use vti interfaces, what are the benefits of these over normal setups ?
Peter Paluch
Hi Carl,
A VTI significantly simplifies the IPsec configuration - instead of creating a crypto map, a simpler crypto profile is created. You do not have to care about the peer or the ACL that selects the interesting traffic to be encrypted, as the peer is identified by the tunnel destination and the IPsec should apply to everything that passes through the tunnel.
In addition, the VTIs are the only flexible way to create a DMVPN if the real routers' IP addresses change over time. With static crypto maps, you would have troubles creating an appropriate ACL to describe the traffic to be encrypted. You could perhaps solve this with dynamic crypto maps but this is all an added hassle. With a VTI, the crypto profile applies to all traffic passing through the tunnel, and its endpoint can be resolved dynamically using NHRP, giving rise to the fundamental DMVPN principle - a multipoint GRE tunnel with dynamically established endpoints.
Using VTIs even allows you to create a pure IPsec tunnel (without GRE) represented by an interface - something that a crypto map can never provide you with.
Best regards,
Peter
