08-06-2008 05:19 AM - edited 03-03-2019 11:02 PM
I want to connect two Routers with a WIC-1T over X21 bach-to-back. Does this work with a CAB-SS-X21FC and a CAB-SS-X21MT for testing pupose? I know that will have to configure the clockrate on the DCE side.
Thomas
Solved! Go to Solution.
08-06-2008 06:31 AM
Tomas,
The WIC-1T has a DB60 interface. The cables you listed use the smart serial connector so they will not work. The following cables should work.
DB15F X21 to DB60 CISCO Cable: CAB-X21FC
DB15M X21 to DB60 CISCO Cable: CAB-X21MT
08-06-2008 06:11 AM
Hi Thomas
I am not too sure of the cable labels you mentioned in your post. But if you have an X21 DTE cable and an X21 DCE cable, and you connect the two DB15 ends together, then yes, this will work to connect two routers together.
I actually have a number of different DCE/DTE connections (X21, RS232,V35, RS449) in my home lab along with the DB60/DB60 back to back cables and they all work, no problem.
Best Regards,
Michael
08-06-2008 06:31 AM
Tomas,
08-06-2008 06:47 AM
I Ment the CAB-X21FC and the CAB-X21FC (without the -SS-) so i will try with them
Thank You
