X.25 Over E1 Link
I have two routers connected over the E1 link via serial interface with the default configuration so encapsulation is on Cisco HDLC.
ROUTER1:
interface Serial0/0
 bandwidth 1544
 ip address 172.30.1.21 255.255.255.252
end
ROUTER2:
interface Serial0/1
 ip address 172.30.1.22 255.255.255.252
 no ip mroute-cache
end
What If I change the encapsulation to X.25? Below is the sample configuration:
ROUTER1:
interface Serial0/0
 encapsulation x25
 no ip mroute-cache
 x25 address 2405005409
 x25 map ip 172.30.1.22 2405005410
ROUTER2:
interface Serial0/1
 encapsulation x25 dce
 no ip mroute-cache
 x25 address 2405005410
 x25 map ip 172.30.1.21 2405005409
 clock rate 128000
 dce-terminal-timing-enable
exit
Kindly let me know If the solution works?
Muhammad Anser Khan
acampbell
Muhammad,
Yes - this should be OK
See link:-
http://www.cisco.com/c/en/us/support/docs/wan/x25-protocols/7921-x25-back.html
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
