02-18-2013 06:23 AM - edited 03-04-2019 07:03 PM
Hello guys.
How can i verify end-toend connectivity for two x.25 routers ? is there a ping command for x.25 ? or what commands can i use on a cisco router to see if it can reach a remote x.25 router.
thanks
02-18-2013 06:51 AM
There are quite few useful commands. But the thing is thta you must be familar with X.25 to understand how to use them. If you aren't and trying Do It Yourself, you will likely loose a lot of time.
02-19-2013 12:04 AM
It's more than 10 years I worked with x25, but one thing popped up in my mind. That is the command "pad", it's similar to the telnnet command. If you have an x25 with number 123456, then use "pad 123456"
/Mikael
