03-11-2009 02:58 PM - edited 03-04-2019 03:54 AM
I'm starting to get confused with this now. Can anyone who's familiar with X25 advice pls
Once a Virtual Channel (VC) is up, can i safely assume that i can have a maximum of 256 sessions per VC?
03-11-2009 08:46 PM
What do you mean by "session" ? A VC is like a point-to-point link, you can carry any type and amount of IP traffic on it.
03-11-2009 09:06 PM
Maybe i should rephrase this. A VC is established when a call/signal is requested. Hence, what's the maximum no of VCs that can be made? Is this 256?
03-11-2009 09:15 PM
Per standard, the maximum number of VCs (combined switched and permanent) is 4095, and cisco supports up to that number as well.
03-11-2009 09:26 PM
-- Edited.
03-11-2009 09:29 PM
-miscom
03-11-2009 09:27 PM
On a NM-16A/S, if i were to configure all ports for synchronous x25 connectivity. How many VCs can a single port hold?
03-11-2009 09:32 PM
As mentioned above, 4095.
Note in real world, more than few VCs per port are seldom used.
03-11-2009 09:56 PM
Ok got it, looked up the DOC-CD
http://www.cisco.com/en/US/docs/ios/wan/command/reference/wan_x1.html#wp1012672
thanks!
