xconnect with EVC on ASR ?
sebastien3
Level 4
Level 4
I would like to be able to bridge two ports in the same xconnect domain. I can't do it and wonder if it is possible to do it ?
I tried the configuration below on an ASR 1000 :
interface GigabitEthernet0/0/0
 no ip address
 negotiation auto
 cdp enable
 xconnect 10.10.10.10 10 encapsulation l2tpv3 pw-class LTPV3
 service instance 1000 ethernet
  encapsulation default
  bridge-domain 10
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
 cdp enable
 service instance 1001 ethernet
  bridge-domain 10
bridge-domain 10
 mac aging-time 600
 ip igmp snooping
sebastien3
Level 4
Level 4
It's not possibled ?
not it possible
for IOS XR you can do that
you config bridge domain and add xconnect (VPWS) under it
https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116453-technote-ios-xr-l2vpn-00.html
MHM
sebastien3
Level 4
Level 4
Hi @MHM Cisco World
I'm using IOS XE... I'm stuck without a solution !
