06-28-2005 05:19 AM - edited 03-03-2019 09:55 AM
hello, I have a problem with my xot/translate configuration. I have a customer witch sends the data in XoT. what i will do is unpack the XoT and then to translate the x25 data to TCP. I ve found a configuration exaple witch says that this should work. whit the debug command deb x25 all, deb translate, deb pad I can see nothing.
Below is my configuration !
version 12.3
service pad from-xot
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service compress-config
no service dhcp
hostname tpkg2f
boot-start-marker
boot system flash:c3745-js-mz.123-9b.bin
boot-end-marker
logging buffered 64000 debugging
no logging console
clock timezone met 1
clock summer-time met recurring last Sun Mar 2:00 last Sun Oct 2:00
no network-clock-participate slot 1
aaa new-model
aaa authentication login default group tacacs+ line
ip subnet-zero
ip tftp source-interface FastEthernet0/0
no ip domain lookup
no ip bootp server
ip cef
x29 profile MIGROS 1:0 2:0 3:0 4:2 5:0 6:0 7:0 8:0 9:0 10:0
x25 routing
no ip address
speed 100
full-duplex
interface FastEthernet0/0.866
description tpkg2f-tpkg1u-Fa6/46 , Anschluss KG VPN IE POST
encapsulation dot1Q 866
ip address XXX.XXX.XXX.XXX 255.255.255.224
no ip proxy-arp
ip accounting output-packets
ip nat inside
standby 3 ip XXX.XXX.XXX.XXX
standby 3 priority 105
standby 3 preempt
standby 3 authentication 43j1q36Q
standby 3 track FastEthernet0/1 20
interface FastEthernet0/1
no ip address
speed 100
full-duplex
interface FastEthernet0/1.504
description tpkg2f-tccc03-Fa6/4 , Anschluss Cablecom Migros
encapsulation dot1Q 504
ip address xxx.xxx.xxx.xxx 255.255.255.224
no ip proxy-arp
ip nat outside
ntp disable
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
ip nat inside source static 172.19.246.220 xxx.xxx.xxx.xxx
no ip http server
ip classless
ip route 172.19.246.220 255.255.255.255 xxx.xxx.xxx.xxx
ip route xxx.xxx.xxx.xxx 255.255.255.0 xxx.xxx.xxx.xxx
ip tacacs source-interface FastEthernet1/1
translate x25 .* profile MIGROS tcp 172.19.246.220 port 8030 stream quiet swap
line vty 0 4
vacant-message ^CC
Your L O G I N T I M E has expired!
If you need my services again, hit <RETURN> to call me back.
^C
line vty 5 10
transport input all
07-04-2005 06:02 AM
This below link help yo to configure the internal packet assembler/disassembler (PAD) facility to make connections with remote devices over the X.25 protocol.
