ZBF issue with remote VPN via virtuel interface on a 2911
lars.arler
Hi again and thanks in advance
I just vent from static firewall to Zone Based Firewall as sugested in another discussion and so far so god and my setup nearly works perfect !! and here is the schematic
My issue is that when I connect remotely via VPN
  • I have access to Internet (Outside)
  • But can't connect to my servers ( DMZ)
My Server (DMZ) and VPN are on the same IP range, not that I think matters.
I'll try to give the VPN connections another IP range later.
Key elements in my config
ip dhcp excluded-address 192.168.100.1 192.168.100.49
ip dhcp excluded-address 192.168.50.1 192.168.50.49
ip dhcp pool VLAN200
 network xx.xx.xx.96 255.255.255.240
 default-router xx.xx.xx.97
 dns-server 8.8.8.8 4.4.4.4
ip dhcp pool VLAN100
 network 192.168.100.0 255.255.255.0
 default-router 192.168.100.1
 dns-server 192.168.100.1
ip dhcp pool VLAN50
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
 dns-server 192.168.50.1
I know the are the same !! / BUT easier to create an overview with fuld naming
class-map type inspect match-any CLASS-L4-IPSEC
 match access-group name IPSEC_TRAFFIC
class-map type inspect match-all CLASS_CRYPTO_IPSEC_TRAFFIC_OUT_TO_SELF_PASS
class-map type inspect match-any CLASS_CRYPTO_IPSEC_TRAFFIC_SELF_TO_OUT_PASS
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any CLASS_SELF_TO_OUT_INSPECT
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any CLASS_OUT_TO_SELF_INSPECT
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any CLASS-APPLE-REMOTE-DESKTOP
 match access-group name APPLE-REMOTE-DESKTOP
class-map type inspect match-any CLASS-APPLE-AFP
 match access-group name APPLE-FILE-SHARING
class-map type inspect match-any CLASS-INTERNET-TRAFFIC
 match protocol http
 match protocol https
 match protocol dns
 match protocol icmp
class-map type inspect match-any CLASS-FTP
 match protocol ftp
 match protocol ftps
class-map type inspect match-any CLASS-SSH
 match protocol ssh
class-map type inspect match-any CLASS-IMAP-SMTP
 match protocol imap
 match protocol smtp
class-map type inspect match-any CLASS-ALLOW_ALL_TRAFFIC_THROUGH
 match access-group name ALLOW_ALL_TRAFFIC_THROUGH
policy-map type inspect POLICY-(PRIVATE-->DMZ)
 class type inspect CLASS-FTP
  inspect
 class type inspect CLASS-SSH
  inspect
 class type inspect CLASS-APPLE-REMOTE-DESKTOP
  inspect
 class type inspect CLASS-APPLE-AFP
  inspect
 class type inspect CLASS-INTERNET-TRAFFIC
  inspect
 class type inspect CLASS-IMAP-SMTP
  inspect
 class type inspect CLASS-L4-IP
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(SELF-->INTERNET)
 class type inspect CLASS_CRYPTO_IPSEC_TRAFFIC
  pass
 class type inspect CLASS_SELF_TO_OUT_INSPECT
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(INTERNET-->SELF)
  pass
 class type inspect CLASS_OUT_to_SELF_INSPECT
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(PRIVATE-->INTERNET)
  inspect
  inspect
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(INTERNET-->DMZ)
  inspect
  inspect
  inspect
 class class-default
  drop log
policy-map type inspect POLICY-(DMZ-->INTERNET)
 class type inspect CLASS-ALLOW_ALL_TRAFFIC_THROUGH
  inspect
 class class-default
  drop log
zone security PRIVATE-ZONE
zone security INTERNET-ZONE
zone security DMZ-ZONE
zone-pair security PRIVATE-TO-DMZ source PRIVATE-ZONE destination DMZ-ZONE
 service-policy type inspect POLICY-(PRIVATE-->DMZ)
zone-pair security PRIVATE-TO-INTERNET source PRIVATE-ZONE destination INTERNET-ZONE
 service-policy type inspect POLICY-(PRIVATE-->INTERNET)
zone-pair security INTERNET-TO-DMZ source INTERNET-ZONE destination DMZ-ZONE
 service-policy type inspect POLICY-(INTERNET-->DMZ)
zone-pair security DMZ-TO-INTERNET source DMZ-ZONE destination INTERNET-ZONE
 service-policy type inspect POLICY-(DMZ-->INTERNET)
zone-pair security SELF-TO-VPN-INTERNET source self destination INTERNET-ZONE
 service-policy type inspect POLICY-(SELF-->INTERNET)
zone-pair security VPN-INTERNET-TO-SELF source INTERNET-ZONE destination self
 service-policy type inspect POLICY-(INTERNET-->SELF)
crypto isakmp policy 150
 encr aes 256
 authentication pre-share
 group 2
crypto isakmp client configuration group SAS-VPN
 key XXXXXX
 dns 208.67.222.222 208.67.220.220
 pool REMOTE-VPN-CLIENTS
 acl 101
crypto isakmp profile SAS-VPN-PROFILE
   match identity group SAS-VPN
   client authentication list userauthen
   isakmp authorization list userauthen
   client configuration address initiate
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set SAS-VPN-1 esp-aes 256 esp-sha-hmac
crypto ipsec profile SAS-VPN-VTUNNEL-PROFILE
 set security-association lifetime kilobytes disable
 set security-association lifetime seconds 86400
 set transform-set SAS-VPN-1
 set isakmp-profile SAS-VPN-PROFILE
interface GigabitEthernet0/0
 description ISP WAN (Wide Area Network)
 ip address XXX.XXX.XXX.190 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 zone-member security INTERNET-ZONE
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN (Local Area Network)
 ip address pool VLAN100
 ip nat inside
 zone-member security PRIVATE-ZONE
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address pool VLAN50
 ip nat inside
 duplex auto
 speed auto
 interface Vlan200
 description HWIC-4ESW_LAN - SERVER PARK
 ip address XXX.XXX.XXX.97 255.255.255.224
 ip nat inside
 zone-member security DMZ-ZONE
interface Virtual-Template1 type tunnel
 description Virtuel VPN Forbindelse
 ip unnumbered GigabitEthernet0/0
 ip nat inside
 tunnel source GigabitEthernet0/0
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile SAS-VPN-VTUNNEL-PROFILE
router eigrp 100
 network 80.0.0.0
 network 87.0.0.0
 network 192.168.0.0
router ospf 123
 network 80.0.0.0 0.255.255.255 area 0
 network 87.0.0.0 0.255.255.255 area 0
 network 192.0.0.0 0.255.255.255 area 0
ip local pool REMOTE-VPN-CLIENTS 80.xx.xx.123 80.xx.xx.126
ip forward-protocol nd
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 87.63.227.189
ip access-list extended ALLOW_ALL_TRAFFIC_TROUGH
permit ip any any
ip access-list extended APPLE-FILE-SHARING
 permit tcp any any eq 427
 permit tcp any any eq 548
ip access-list extended APPLE-REMOTE-DESKTOP
 permit tcp any any eq 22
 permit udp any any eq 3283
 permit tcp any any eq 5900
 permit udp any any eq 5900
 permit tcp any any eq 3283
ip access-list extended EIMS-MAILSERVER
 permit tcp any any eq 587
permit tcp any any eq smtp
permit tcp any any eq 143
ip access-list extended EIMS-MAILSERVER-ADMIN
permit tcp any any eq 4199
ip access-list extended IPSEC_TRAFFIC
 permit udp any eq isakmp any
permit udp any eq non500-isakmp any
 permit ahp any any
 permit esp any any
 permit udp any any eq non500-isakmp
 permit udp any any eq isakmp
access-list 1 permit 192.168.100.0 0.0.0.225
access-list 1 permit 192.168.50.0 0.0.0.255
access-list 123 permit esp any any
access-list 123 permit udp any any eq non500-isakmp
access-list 123 permit ahp any any
access-list 123 permit udp any any eq isakmp
based on your configuration, I have come up with the below. Since I haven't been able to match all the classes and policies to what is already in your configuration, I have created new ones. Basically, you need two zone pairs. In the out to self policy, I am not sure if you have to inspect or pass the IPSEC traffic, so toggle these values.
permit ahp any any
permit esp any any
policy-map type inspect POLICY_OUT_TO_SELF
class type inspect CLASS_OUT_TO_SELF
inspect or pass <-- toggle these values
class class-default
drop log
zone-pair security OUT_TO_SELF source INTERNET-ZONE destination self
service-policy type inspect POLICY_OUT_TO_SELF
class-map type inspect match-any CLASS_SELF_TO_OUT_PASS
match protocol icmp
match protocol tcp
match protocol udp
policy-map type inspect POLICY_SELF_TO_OUT
class type inspect CLASS_SELF_TO_OUT_PASS
pass
inspect
class class-default
drop log
zone-pair security SELF_TO_OUT source self destination INTERNET-ZONE
service-policy type inspect POLICY_SELF_TO_OUT
7 Replies 7
post the full running configuration. I cannot see how your client pool is configured. Make sure that it contains an ACL that allows traffic from the DMZ to any. It should look like this (the lines in bold must match):
crypto isakmp client configuration group cisco
key cisco
dns 8.8.8.8
domain cisco.com
pool client_pool
acl 101
interface Vlan200
ip nat inside
access-list 101 permit ip XXX.XXX.XXX.97 0.0.0.31 any
hostname R2911
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.154-3.M.bin
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
no logging console
enable secret 5 $1$8LqH$9JXseHd62tFJvW3cp9gxp.
aaa new-model
aaa authentication login userauthen local
aaa authorization network userauthen local
aaa session-id common
memory-size iomem 25
no ipv6 cef
no ip source-route
 network XXX.XXX.XXX.96 255.255.255.240
 default-router XXX.XXX.XXX.97
ip dhcp pool VLAN50
ip domain name mediadesign.dk
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip name-server 62.243.0.166
ip name-server 194.192.207.166
ip cef
ip cef accounting non-recursive
crypto pki trustpoint TP-self-signed-2506629599
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2506629599
 revocation-check none
 rsakeypair TP-self-signed-2506629599
crypto pki certificate chain TP-self-signed-2506629599
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32353036 36323935 3939301E 170D3137 31313231 31383331
  34355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35303636
  32393539 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B864 001074AA 3ACB326E 0746CC7D 5A1A7E4B 92667702 844CEF49 166B0D95
  DAF80B11 3A0C8AF0 A4A4C5D4 491FB34D 28F83027 8E882C56 16890795 80538DF4
  754EA389 DBCD4C5F 24ED9E61 D4A5FD94 B2A6DBAA D2A624EB 23D4E3DB CD2B27EC
  73277F09 5908425D 70D1212B 946D3A92 9C628C55 96FB2A75 376BF8A4 B2632D47
  B3030203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1421FD81 D44399EA FFD554A4 97C6A7DC C3C72BD8 FD301D06
  03551D0E 04160414 21FD81D4 4399EAFF D554A497 C6A7DCC3 C72BD8FD 300D0609
  2A864886 F70D0101 05050003 8181008E 5E8AFBFC 86243F4E AD1785BC 72C1FC2C
  F2CB747E E70E5983 F1A1F60B 539C67F7 028712AD 1A9A3154 7459C967 A51AE7CD
  1C8DB2A5 0BF089EB B9B1A24C 951C677B CBD18212 CC59A5A3 8F3AB203 9B839185
  93798F89 141FCCBD F67CCDE2 1428963A 982720ED 59D95C02 DCC9CD7D B842BE47
  C37855E0 7901AFD3 B71FA3A4 B48ADD
  quit
voice-card 0
license feature snasw
license udi pid CISCO2911/K9 sn FTX1814ALDX
license accept end user agreement
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
hw-module pvdm 0/1
object-group network DMZ-FILEMAKER
 description FILEMAKER server in DMZ
 host XXX.XXX.XXX.99
object-group network DMZ-MAIL
 description EMAIL servers in DMZ
 host XXX.XXX.XXX.100
 host XXX.XXX.XXX.115
object-group network DMZ-MEDIADESIGN
 description MEDIADESIGN file-www-ftp server in DMZ
 host XXX.XXX.XXX.101
 host XXX.XXX.XXX.102
 host XXX.XXX.XXX.103
 host XXX.XXX.XXX.104
 host XXX.XXX.XXX.105
 host XXX.XXX.XXX.106
 host XXX.XXX.XXX.107
 host XXX.XXX.XXX.108
 host XXX.XXX.XXX.109
 host XXX.XXX.XXX.110
username XXX
username xxx
redundancy
ip ssh time-out 60
ip ssh version 2
class-map type inspect match-any L4-ip-class
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any INTERNET-TRAFFIC-CLASS
 match protocol http
 match protocol dns
 match protocol icmp
class-map type inspect match-all FILEMAKER-SERVER-CLASS
 match access-group name INTERNET-->DMZ-FILEMAKER
 match access-group 105
class-map type inspect match-any NTP-CLASS
 match protocol ntp
class-map type inspect match-all MEDIADESIGN-SERVER-CLASS
 match access-group name INTERNET-->DMZ-MEDIADESIGN
 match class-map NTP-CLASS
class-map type inspect match-any APPLE-REMOTE-DESKTOP
class-map type inspect match-any FTP-CLASS
 match protocol ftp
 match protocol ftps
class-map type inspect match-any SSH-CLASS
 match protocol ssh
class-map type inspect match-any APPLE-AFP
class-map type inspect match-any IMAP-SMTP-CLASS
 match protocol imap
 match protocol imap3
 match protocol imaps
 match protocol smtp
 match protocol pop3
 match protocol pop3s
class-map type inspect match-all MAIL-SERVER-CLASS
 match access-group name INTERNET-->DMZ-EMAIL
 match class-map IMAP-SMTP-CLASS
 match access-group name EIMS-MAILSERVER
class-map type inspect match-any L4-ipsec-class
 match access-group name IPSECtraffic
policy-map type inspect PRIVATE-->DMZ-POLICY
 class type inspect FILEMAKER-SERVER-CLASS
  inspect
 class type inspect FTP-CLASS
  inspect
 class type inspect SSH-CLASS
  inspect
 class type inspect APPLE-REMOTE-DESKTOP
  inspect
 class type inspect APPLE-AFP
  inspect
 class type inspect L4-ip-class
  inspect
 class type inspect MAIL-SERVER-CLASS
  inspect
 class class-default
  drop log
policy-map type inspect ALLOW-ALL-ISAKMP
 class type inspect L4-ipsec-class
  pass
 class class-default
  drop
policy-map type inspect PRIVATE-->INTERNET-POLICY
 class type inspect INTERNET-TRAFFIC-CLASS
  inspect
  inspect
  inspect
 class class-default
  drop log
policy-map type inspect INTERNET-->DMZ-POLICY
  inspect
 class type inspect MEDIADESIGN-SERVER-CLASS
  inspect
  inspect
  inspect
  inspect
 class class-default
  drop log
policy-map type inspect DMZ-->INTERNET
  inspect
  inspect
 class class-default
  drop log
zone security VPN-ZONE
 service-policy type inspect PRIVATE-->DMZ-POLICY
 service-policy type inspect PRIVATE-->INTERNET-POLICY
 service-policy type inspect INTERNET-->DMZ-POLICY
 service-policy type inspect DMZ-->INTERNET
zone-pair security VPN-TO-SELFXX source INTERNET-ZONE destination self
 service-policy type inspect ALLOW-ALL-ISAKMP
 encr aes 256
 group 2
 key XXXXXX
   virtual-template 1
interface Loopback0
 ip address 10.108.1.1 255.255.255.0
interface Embedded-Service-Engine0/0
 no ip address
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
interface FastEthernet0/1/0
 switchport access vlan 200
 no ip address
interface FastEthernet0/1/1
 no ip address
interface FastEthernet0/1/2
 no ip address
interface FastEthernet0/1/3
 no ip address
 ip nat inside
interface Vlan1
 no ip address
interface Vlan50
 description GUEST NETWORK DHCP POOL
 no ip address
 ip nat inside
interface Vlan100
 description INTERNAL NETWORK DHCP POOL
 ip address dhcp
 ip nat inside
interface Vlan200
 ip nat inside
router eigrp 100
 network 80.0.0.0
 network 87.0.0.0
 network 192.168.0.0
router ospf 123
ip local pool REMOTE-VPN-CLIENTS XXX.XXX.XXX.123 XXX.XXX.XXX.126
no ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.189
ip access-list extended INTERNET-->DMZ-EMAIL
 permit ip any object-group DMZ-MAIL
ip access-list extended INTERNET-->DMZ-FILEMAKER
 permit ip any object-group DMZ-FILEMAKER
ip access-list extended INTERNET-->DMZ-MEDIADESIGN
 permit ip any object-group DMZ-MEDIADESIGN
ip access-list extended IPSECtraffic
 permit esp any any
 permit ahp any any
access-list 1 permit XXX.XXX.XXX.96 0.0.0.31
access-list 105 remark ## FILEMAKER SERVER ##
no cdp run
control-plane
mgcp profile default
gatekeeper
 shutdown
telephony-service
 max-ephones 10
 max-conferences 8 gain -6
 transfer-system full-consult
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 session-timeout 30
 transport input ssh
line vty 5 15
 session-timeout 30
 transport input ssh
scheduler allocate 20000 1000
end
permit ahp any any
permit esp any any
class class-default
drop log
match protocol icmp
match protocol tcp
match protocol udp
pass
inspect
class class-default
drop log
Thanks for your time Georg
Your solution didn’t solve the issue -
But it boosted the general response time and flov speed tremendously
So could have been and still was some of the problem.
So nice spottet
I think I have to analyse my Classes and Policies and Zone-pairs a little deeper
Before implementing ZBF again
Somebody on the list pointet at that I needed 2 ZONE-PAIR’s one for both ways
INTERNET to SELF
SELF TO INTERNET
That fixed my problem
But then I found out that ZONE-PAIR "INTERNET to DMZ" wasn’t running smooth
I could ping through but UDP keeps dropping in the log and I have no connection in or out for Application services.
I have to dig a little deeper into the manuals to see what’s wrong ;-)
Thanks again
can you, for future reference, post your final, working (if it is working) configuration ?
Hello
I'm puzzled by the zone-pair to SELF set up !!
zone-pair security VPN-TO-SELFXX source INTERNET-ZONE destination SELF
Shouldn't the SELF not have free access to all networks by default ??
How should I approach this problem solving ??
No
My understanding the self zone is for control plane traffic , to/from router only (non transit traffic) By default traffic from the other zones are allowed to access the router so amending this self zone allows you control the access to the router from the other zones.
I see you have a pass action applied to the vpn-self zone pair now when using this action you need to make allowances for the return traffic  meaning you need an additional zone-pair in the other direction with the pass action.
Can you confirm what exactly isnt working, connection from the internet to you router or connection to/from internet and dmz zones?
Kind Regards
Paul
Hi Paul and thanks for taking your time.
PRIVAT --> INTERNET = Works
PRIVAT --> DMZ = Works
DMZ --> INTERNET = Works
INTERNET --> DMZ = WORKS
It is when I try to connect via REMOTE VPN
That I can browse the Internet - but I can't browse my own web-server and mail-server
So it seems as that I can't connect to the DMZ-ZONE when on REMOTE VPN
