04-15-2019 08:03 AM - edited 04-15-2019 08:44 AM
Hello all,
I am trying to add vBond to vManage but I faced some difficulties in this process. Sorry, if my questions are preliminaries:
- Since I need to have two ip addresses one for VPN and one for system-ip, can they be on the same interface?
I mean If I have one interface can I use IPv4 for system-ip and IPv6 for VPN?
- If not, as much as I try to add a new interface in vBond it dos not detect it. For adding new network adapter should I perform
any special command? Moreover, can I access to the root user?
Kind Regards,
04-16-2019 12:59 PM
04-18-2019 10:40 PM
Assuming you are using vEdge cloud, system IP corresponds to Loopback (internal) should be different from the active IP which you assign to transport/control tunnel (vpn 0) , have your VPN 512 for mgmt
now from vManage, add the controller using the mgmt IP and proceed.
in VM settings , you should be able to add network adapters and map it to corresponding vSwitch / port groups !
