Adding vBond and vSmart to vManage
helloguys
Software version 19.2.2.
I'm following https://codingpackets.com/blog/cisco-sdwan-self-hosted-lab-part-2/ to add vBond and vSmart.
I went to vManage > Configuration > Devices > Controllers > Add Controller.  Enter vBond's VPN 0 IP and credential.  vBond was added, but not in-sync.
When I tried to view vBond running configuration from the device list, I saw a message "[vmanagedb] No system ip found for uuid 90f39711-0829-4cd7-8186-e3072299b4d8".
Troubleshooting steps performed:
1) Review vBond configuration.  Make sure system-ip was configured.
2) Delete vBond from device list and re-add.  Purposely entered a wrong credential and get the message "authentication failed".  This means vManage was actually communicating with vBond to do authentication.
3) Reboot vBond.
vBond configuration:
system
host-name vBond1
system-ip 1.1.1.2
site-id 1
admin-tech-on-failure
no route-consistency-check
organization-name "SD-WAN Lab 2020"
vbond 100.64.1.12 local vbond-only
 aaa
auth-order local radius tacacs
usergroup basic
task system read write
task interface read write
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
usergroup tenantadmin
user admin
password $6$efEnkVadlbJFXysS$Nj4BiImulNcVIk.Zqo2pv4zKsYwkwwViWE6K78rs4lDsKOuMuUI2LtorDHU5SfRRGNdcgd1u0uJydGAVg.KpR1
logging
disk
enable
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
authentication-type ah-sha1-hmac sha1-hmac
vpn 0
interface ge0/0
ip address 100.64.1.12/24
no shutdown
vpn 512
interface eth0
ip address 192.168.21.12/24
no shutdown
helloguys
OK, I seemed to fix the problem but not quite understand why.
I carefully reviewed https://codingpackets.com/blog/cisco-sdwan-self-hosted-lab-part-2/.  When adding vBond to vManage, VPN0 interfaces *need* to be in the following combination?
1) vManage VPN0 interface needs to have "tunnel-interface".  (Enable control pane)
2) vBond VPN0 interface needs to have "no tunnel-interface".  (Disable control pane)
After vBond was successfully added, then go to vBond CLI to add "tunnel-interface" to VPN0 (enable control pane).  Can someone explain why it has to be this way?
When adding vBond to Vmanage , vManage need to establish  a  NETCONF connection to vBond.By Default , the vBond interface is configured with tunnel-interface , this will lock down the interface and also prevent incoming NETCONF connection from vManage and DTLS tunnel will not be established (if you just leave the tunnel-interface command under vBond VPN0 interface without additional config)
Therefore , to successfully  add the vBond to vManage , you can do one of the following :
option1 :  Disable the tunnel-interface on vBond VPN0 interface , then add the vBond to vManage ,provision vBond certificate ,  then enable back the tunnel-interface on vBond VPN0 interface ( add encapsulation ipsec , and allow-service all). Adding the tunnel-interface on vBond VPN0 interface will allow DTLS tunnel to be established between vManage and vBond because we have added allow-service all)
option 2:  From the begging , add tunnel-interface  on vBond VPN0 interface (by default is added)  , but  also add encapsulation ipsec , and allow-service all . then add the vBond to vManage  (This will work because you allow-service all ) ,provision vBond certificate. DTLS tunnel now can be established between vManage and vBond .
Ali
