Anyone successfully get bulk api device system status info via API ?
andreyka64
Every iteration I've attempted to get device system stats, I can't seem to get any data. Small and large time ranges, with no luck.
Anyone have a sample working URL request they can share because I can't get this endpoint to return anything.
Other endpoints work totally fine, but nothing from the bulk api's.
URL: https://vmanage-ip-address/dataservice/data/device/state/devicesystemstatusstatistics?startDate=yyyy-mm-ddThh:mm:ss&endDate=yyyy-mm-ddThh:mm:ss
https://sdwan-docs.cisco.com/Product_Documentation/Command_Reference/Command_Reference/vManage_REST_APIs/Bulk_APIs/Statistics#Response_Object_for_Bulk_Statistics_API_Calls
andreyka64
Anybody have any clue/insight ?
Still no luck getting the bulk stats via the API.
