Cisco SDWAN Certificates for controllers/ Clusters
craneman1
I have the new 20.3.2 code.  When initially setting up say the first 3 vManages for cluster...   should I manaually enroll the Enterprise Root CA by CLI... or enroll it through the GUI Administration Settings?... What is the difference?  Because I am having trouble with the GUI method and have not done the manaual cli method as of now...
A second question is should I cluster the 3 vManages first and then do the certificates?  or do the certificates on each vManage and then cluster?..  Seems like we might want to cluster them first and if I do that would I need to just do one vManage with the root and it shares it with the other 2 vManages?
Thanks!
0 Replies 0
