can not access console ISR1100X-4G
when i tried to login to the console port of the ISR 1100X-4g using putty or tera term it shows complicated symbols while using baud rate 115200
2 Accepted Solutions
OK @AbdElRahman.Ashraf
115200, 8, 1, N (No partity)
The console cable is ok with other routers/switches ?
Check serial to USB cable driver, @AbdElRahman.Ashraf
Re install this driver, ensure is it well recognized.
Best regards
Yes @AbdElRahman.Ashraf
same adapter ?
Check serial to USB cable driver@AbdElRahman.Ashraf
Best regards
10 Replies 10
Check setting below
MHM
when using 9600 nothing appears at the putty screen
From Cisco guide
  • 115200 baud (check this for 1100 series it only accept this value)
  • 8 data bits
  • no parity
  • 1 stop bit
  • no flow control
not responding
M02@rt37
Hello @AbdElRahman.Ashraf
Which console cable do you use? Do you have also an adapter serial2usb ?
Best regards
Hello Mo
I use db9 console connected to a serial to USB cable
Best regards
Hi Mo
I have tried with another laptop with different cable and faced the same issue
same adapter ?
Best regards
Hi Mo
thanks for your help the problem was solved by using a different USB to Serial cable
best Regards
Abdelrahman
