Cannot establish control connections between Vedge and Vsmart
Chaminda1912
Hi ,
I cannot get control connection established between Vedge and Vsmart and tshoot steps i took as below ..
vEdge2-1# show control local-properties
personality vedge
sp-organization-name SDWAN-LAB-01
root-ca-chain-status Installed
certificate-status Installed
certificate-validity Valid
certificate-not-valid-before Mar 15 22:23:37 2025 GMT
certificate-not-valid-after Mar 13 22:23:37 2035 GMT
dns-name 192.168.0.200
site-id 2
domain-id 1
protocol dtls
tls-port 0
system-ip 1.1.2.2
chassis-num/unique-id 9044e61f-cf4e-484c-2c88-3feda0b89890
serial-num 5C881646
token Invalid        < Certificate says valid but token shows invalid >
keygen-interval 1:00:00:00
retry-interval 0:00:00:18
no-activity-exp-interval 0:00:00:20
dns-cache-ttl 0:00:02:00
port-hopped TRUE
time-since-last-port-hop 0:00:00:45
pairwise-keying Disabled
embargo-check success
number-vbond-peers 1
INDEX IP PORT
0 192.168.0.200 12346
number-active-wan-interfaces 1
so i re-applied the token again and now wan edge shows up in the dashboard but  show control local-properties shows no certificate installed.
personality vedge request vedge-cloud activatsp-organization-name SDWAN-LAB-010b89890 token 5C881646
organization-name SDWAN-LAB-01-number 9044e61f-cf4e-484c-2c88-3feda0b89890 token 5C881646
certificate-status Not-Installed
certificate-validity Not Applicable
certificate-not-valid-before Not Applicable
certificate-not-valid-after Not Applicable
site-id 2
domain-id 1
protocol dtls
tls-port 0
system-ip 1.1.2.2
serial-num No certificate installed
token 5C881646
port-hopped TRUE
time-since-last-port-hop 0:00:02:44
INDEX IP PORT
This was emulated in my eve-ng built on esxi server and vmanage has 32 GB memory /vedge has 4GB/Vsmart has 4GB memory as well.
please advise
12 Replies 12
balaji.bandi
Do you know if the issue is only with site two, vedge? How about other devices?
Check on the Vsmart console - do you see any errors?
For testing, wipe one of the nodes start from the beginning.
Follow deployment guide.
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/SD-WAN-End-to-End-Deployment-Guide.pdf
BB
@balaji.bandi will test again. It's happening for all the VEdge and CEdge devices.Will perform further tests and advise
@balaji.bandi I tried wiping out one node and reconfiguring it, but now the node is not coming up, and I cannot see the CSR Certificate transition either.
I have used in my Lab sometime back works as expected :  ( edge onboard Blog missing, i fix that URL soon when i get chance)
https://www.balajibandi.com/?p=2028
BB
Try to enter below command on the vEdge
- clear omp all
@Jeongjun Park control connections are down so there will be no use of clearing the OMP routes .
mohamedyare
Can you confirm that you have configured vbond under system, secondly check is vsmart is connected to vbond
@mohamedyare yes vbond is under system and vmart ,vbond and vmanage are all reachable.
share show control connections show control connection-history and show control local-properties both from vsmart and vedge router.
Note: better if in text file for easier checking
HTH,
@Kanan Huseynli I have attached config files and screenshots as requested.
When i check the edge routers , it shows certificate is installed and the controller is up, but vmanage shows down. when i reapply the chassis number and token vmanage shows vedge is up but show control local-properties command shows no certificate installed and vmanage -->montitor shows not reachable (screenshot attached)
mohamedyare
DCONFAIL is a network connectivity problem. Please check the network connectivity
@mohamedyare all devices are reachable ..Can't see any network issues.
