Centralized Policy not works as expected
dragonhunt9111
Dear friends,
I have an issue in with very simple centralized policy like below:
I already ping , traceroute OK between site2 to site3 as picture above.
Then I create centralized policy , make anything (IP protocol) goes from PC9 to PC10 , will prefer mpls color.
My policy is:
policy
 sla-class hai-sla-class
  loss    10
  latency 200
  jitter  300
 app-route-policy _hai-vpn-list_any_via_mpls
  vpn-list hai-vpn-list
   sequence 1
    match
     source-ip 0.0.0.0/0
   protocol  4
    action
     sla-class hai-sla-class preferred-color mpls
 lists
   vpn 10
  site-list hai-site-list
   site-id 2-3
apply-policy
But when I test by simulator tool in vmanage, it always shows that traffic goes both mpls and biz-internet
And one more thing is, when I change protocol number from 4 (IP) to 1 (ICMP), then it goes as expected (via mpls only)
Then it goes via MPLS as expected:
I don’t know why.
Please help me explain
Thanks you!!!
dragonhunt9111
Finally, maybe I found the root cause, it maybe a limitation of virtual device in eve.
First, I just try a simple policy like this: ( i see from youtube clip, tks https://www.youtube.com/watch?v=KR4jqWmcRTk)
policy
loss 10
latency 200
jitter 300
app-route-policy _vpn10_via_mpls
vpn-list vpn10
sequence 1
match
source-ip 0.0.0.0/0
app-list voice-ip ( I include rtp and sip in this list)
action
Then I use simulator tool (with rtp app) , it goes via exactly mpls line.
But maybe the limitation of virtual device in EVE:
- if I choose another app, ex:gmail,... (which is not in my voice-ip list), it goes via 2 line ( as expected)
- Then I choose rtp again, it also goes via both 2 lines <--Maybe this is bug of eve device
- If I refresh page, it goes via mpls as i want.
Thanks !!
9 Replies 9
SLA prefer is use only when both path criteria is match,
so both path have same SAL criteria or internet is better than MPLS ?
MHM
Hi MHM,
i think both lines are same, because it is in eve-ng lab, no big delay, and no packet loss
MHM
HI MHM.
When I remove command "protocol 1", it works as I expected. Tks you.
But when I want to make some protocols, example: telnet prefer going via mpls. It still goes via both lines
This is my config:, pls help
P/S: I test removed command "protocol 6" (TCP) but still goes via both
So NOW we agree that protocol 1 is work only for ICMP.
now for telnet
EDGE-1 telnet to EDGE-2
the telnet from TCP port to known 23
so we use centralize policy and push to both vedge it not work since we specify the TCP port to be 23
solution is push one policy
for EDGE-1
using protocol 6 (TCP)
using Port 23 as destination
and using color strict in EDGE-2
and start telnet from EDGE-1 to EDGE-2
MHM
Also you can push one policy for each edge
EDGE-1/2
Use source and destiantion (no 0.0.0.0)
The source and destiantion is flap for each policy match lan behind each vedge router
MHM
because you have wrong match. Protocol number 4 means IP-in-IP encapsulation. It does not mean IP protocol, you indeed have IP procotol at later 3. IP protocol number explains what is encapsulated inside IP header (TCP, UDP, IP, GRE, ICMP, OSPF etc.).
Simple, remove protocol 4 in match criteria and it will work as expected. Right now ,you don't have matching traffic, thus it is forwared based on routing > ECMP.
HTH,
Can you share latest policy and also "show app-route stats"? Plus, do you have data policy?
HTH,
dragonhunt9111
policy
loss 10
latency 200
jitter 300
vpn-list vpn10
sequence 1
match
source-ip 0.0.0.0/0
action
Thanks !!
