12-30-2023 12:47 AM - edited 12-30-2023 01:12 AM
Dear friends,
I have an issue in with very simple centralized policy like below:
I already ping , traceroute OK between site2 to site3 as picture above.
Then I create centralized policy , make anything (IP protocol) goes from PC9 to PC10 , will prefer mpls color.
My policy is:
policy
sla-class hai-sla-class
loss 10
latency 200
jitter 300
app-route-policy _hai-vpn-list_any_via_mpls
vpn-list hai-vpn-list
sequence 1
match
source-ip 0.0.0.0/0
protocol 4
action
sla-class hai-sla-class preferred-color mpls
lists
vpn 10
site-list hai-site-list
site-id 2-3
apply-policy
But when I test by simulator tool in vmanage, it always shows that traffic goes both mpls and biz-internet
And one more thing is, when I change protocol number from 4 (IP) to 1 (ICMP), then it goes as expected (via mpls only)
Then it goes via MPLS as expected:
I don’t know why.
Please help me explain
Thanks you!!!
Solved! Go to Solution.
01-06-2024 06:29 AM - edited 01-06-2024 06:35 AM
Finally, maybe I found the root cause, it maybe a limitation of virtual device in eve.
First, I just try a simple policy like this: ( i see from youtube clip, tks https://www.youtube.com/watch?v=KR4jqWmcRTk)
policy
loss 10
latency 200
jitter 300
app-route-policy _vpn10_via_mpls
vpn-list vpn10
sequence 1
match
source-ip 0.0.0.0/0
app-list voice-ip ( I include rtp and sip in this list)
action
Then I use simulator tool (with rtp app) , it goes via exactly mpls line.
But maybe the limitation of virtual device in EVE:
- if I choose another app, ex:gmail,... (which is not in my voice-ip list), it goes via 2 line ( as expected)
- Then I choose rtp again, it also goes via both 2 lines <--Maybe this is bug of eve device
- If I refresh page, it goes via mpls as i want.
Thanks !!
12-30-2023 01:21 AM
SLA prefer is use only when both path criteria is match,
so both path have same SAL criteria or internet is better than MPLS ?
MHM
12-30-2023 03:24 AM
Hi MHM,
i think both lines are same, because it is in eve-ng lab, no big delay, and no packet loss
12-30-2023 03:32 AM - edited 01-01-2024 01:24 PM
MHM
12-31-2023 06:11 AM
HI MHM.
When I remove command "protocol 1", it works as I expected. Tks you.
But when I want to make some protocols, example: telnet prefer going via mpls. It still goes via both lines
This is my config:, pls help
P/S: I test removed command "protocol 6" (TCP) but still goes via both
01-01-2024 01:31 PM
So NOW we agree that protocol 1 is work only for ICMP.
now for telnet
EDGE-1 telnet to EDGE-2
the telnet from TCP port to known 23
so we use centralize policy and push to both vedge it not work since we specify the TCP port to be 23
solution is push one policy
for EDGE-1
using protocol 6 (TCP)
using Port 23 as destination
and using color strict in EDGE-2
and start telnet from EDGE-1 to EDGE-2
MHM
01-03-2024 02:38 AM
Also you can push one policy for each edge
EDGE-1/2
Use source and destiantion (no 0.0.0.0)
The source and destiantion is flap for each policy match lan behind each vedge router
MHM
12-30-2023 03:25 AM
because you have wrong match. Protocol number 4 means IP-in-IP encapsulation. It does not mean IP protocol, you indeed have IP procotol at later 3. IP protocol number explains what is encapsulated inside IP header (TCP, UDP, IP, GRE, ICMP, OSPF etc.).
Simple, remove protocol 4 in match criteria and it will work as expected. Right now ,you don't have matching traffic, thus it is forwared based on routing > ECMP.
01-03-2024 04:09 AM
Can you share latest policy and also "show app-route stats"? Plus, do you have data policy?
policy
loss 10
latency 200
jitter 300
vpn-list vpn10
sequence 1
match
source-ip 0.0.0.0/0
action
Thanks !!
