Cisco ACI own laboratory
alexm2023
   I am trying to build my own Cisco ACI LAB and i need help/advice:
    I have already one spine and two leafs, and also 2 DELL servers in cluster in Vcenter
    The remaining issue is how do i solve the APIC part.
     I understand that i can't have only APIC in vmware, i need to have a physical one. Can i install APIC software on any brand bare metal server? i need to buy UCS? i have found a UCS c220 M3 to buy cheap , is that enough?
   After i buy the physical server and download for example APIC 4.2 iso image and i install it on UCS server, can i use a trial, evaluation license to discover and configure my spine and leafs? do i need to buy a license? how much it costs? Can i rent one?
   I want the cheapest version how can i have an APIC to discover and configure my switches.
Thank you
abhjha2
Assuming you have Spine and Leafs running on ACI version.
You cannot download and install APIC software on any UCS server and use it as APIC phy h/w as it uses dedicated Product ID "APIC-Server-X" where x can be M or L series
However you can try to use vAPIC
