10-02-2024 12:34 PM
I am testing a Viptela to IOS-XE upgrade on an ISR1100-4G (20.9.5.1 > 17.9.4a). It's been well over an hour now since I started the upgrade? How long should it take? I am following this process:
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/218060-configure-sd-wan-nutella-boxes-from-vipt.html#toc-hId-350794783
Thanks.
10-02-2024 12:42 PM
usually it takes less than 10 minutes, can you connect via console and check?
Log in to Community
