Cisco C8300-2N2S-4T2X with AppQoE License
Support ACME
Dear ALL,
We are looking to use C8300-2N2S-4T2X with SD-WAN deployment, and want to use AppQoE feature, Is it IOSXE-CTRL-MODE-PF included the AppQoE license? or any SKU for AppQoE ?
Support
2 Accepted Solutions
you need DNA subscription for SD-WAN features. There are 3 types. Essential includes only TCP optimization from AppQoE.
Other features require DNA advantage (or higher version DNA premier).
https://www.cisco.com/c/dam/m/en_us/products/software/dna-software/dna-software-sd-wan-routing-matrix/pdf/Cisco_DNA_Software_SD-WAN_and_Routing_Matrices.pdf
HTH,
maybe some information is updated, but even May 2023 doc refers to that link:
https://www.cisco.com/c/en/us/products/collateral/software/one-wan-subscription/nb-06-dna-sw-rout-sub-faq-ctp-en.html
Still, it is noted that some basic features are included in essentials, thus and most probably full AppQoE features require Advantage technology package.
HTH,
HTH,
That matrix is outdated, premier how has SIG, adv has all the standard sd-wan feature and even ess. is even useful now.
HTH,
