Cisco cEdge ISR4331 Factory reset
Elena.Madrigal
Hello All
¿ Anybody knows to how to factory reset trought CLI command a Cisco cEdget ISR 4331 with SD-WAN  firmware?
a vEdget is with request sfotware reset... but in cEdge routers this command is not supported.
Cheers
Elena.Madrigal
request platform software sdwan software reset.
The problem is solved
6 Replies 6
Elena.Madrigal
Sdiana
Hi Elena,
How did you manage to factory reset the cEdge router? I want to wipe out the cEdge ISR 4451 config.
dada27
To Reset Config use these commands:
Device# request platform software sdwan config reset
Device# reload
Sdiana
Does this command remove certificate too? I need to wipe config and certificate from a SDWAN cEdge router.
Thank you.
Hello.
I think this command doesnt remove the certificate.
SD-WAN cEdge router uses pre-installed certificate to be onboarded. (TPM/SUDI)
It provides a hardware-derived secure boot process.
Why do you want to clear the certificate ?
I assume your referring to the root-cert-chain certificate, right? Not the on-boarding certificate for VBOND.
