Cisco SD-WAN - BGP Router ID
RS19
Level 4
Level 4
I am using SD-WAN & I am planning the below.
The SD-WAN router will be part of 1 AS say 65001
- 2 VRFs will be created under the AS 65001
Would like to check if the below is possible
VR1 1: Router ID say 1.1.1.1
VR2 2: Router ID say 2.2.2.2
Is it possible to have 2 different router IDs on a single SD-WAN device under a single AS ?
RS19
Level 4
Level 4
Any help
Yes. It is possible and it works.
i.e., You can have 2 different RIDs on a Single SD-WAN device under a single (BGP) AS
Just now verified it in the lab.
Version Tested on: 17.03.02.0.3785
Hope it helps.
